dodge neon question #693263
05/09/10 04:01 PM
05/09/10 04:01 PM
so cal,cali
calimoparguy Offline OP
so cal,cali
I have a 2001 dodge neon.I am having a problem with it.It starts up then dies.If i unplug the pcv hose it will stay running and seems to run fine but everytime i reconnect the pcv hose it dies.....any ideals???????
Re: dodge neon question [Re: calimoparguy] #693264
05/09/10 06:33 PM
05/09/10 06:33 PM
so cal,cali
so cal,cali
anyone??
Re: dodge neon question [Re: calimoparguy] #693265
05/09/10 07:33 PM
05/09/10 07:33 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Sounds like the throttle body idle passages are either carboned up or possible idle air control motor is stuck. JMO.
Re: dodge neon question [Re: Todd] #693266
05/09/10 08:49 PM
05/09/10 08:49 PM
so cal,cali
so cal,cali
well,i took the idle air control motor off and sprayed it out real good(was bunch of gunk in it)and put it back on....so far so good....car will now run with vacuum lines hooked up.....wooow hooo...thanks
