Changing Valve Springs... #692997
05/09/10 09:46 AM
05/09/10 09:46 AM
Middle River, MD
Mapandjlp Offline OP
Middle River, MD
Once a valve job has been done, is it ok to change the valve springs or will the valves need to be reseated?
Re: Changing Valve Springs... [Re: Mapandjlp] #692998
05/09/10 09:59 AM
05/09/10 09:59 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
You won't need to reseat the valves. In fact you don't have to remove the heads to do it.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
