Mallory 250 fuel pump
#692561
05/08/10 07:24 PM
05/08/10 07:24 PM
Posts: 325 Greenville, WI
Big B
Greenville, WI
I have a Mallory 250 pump with a return style regulator. I have to set my fuel psi really high(9psi) just to compensate for fuel psi drop on launch. In 1st it drops to 5psi, 2nd 6psi, then in 3rd it recovers to 7psi. This is on a 730hp 493. Is this pump not putting out enough psi to compensate for the g's on launch? How much is this effecting my a/f ratio? Im thinking about ditching this pump and getting a Product Engineering 460.
Re: Mallory 250 fuel pump
[Re: Big B]
#692562
05/08/10 07:29 PM
05/08/10 07:29 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Ditch the return style regulator. The pump has its own return port, just return it back to the fuel cell and dead head the fuel pressure to the regulator. I have run 1 second flat 60ft with that pump making 850 ish HP in a digger and never once had a problem. Best electric fuel pump I have had to date.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Big B]
#692564
05/08/10 07:46 PM
05/08/10 07:46 PM
Bob_Coomer
Rock Springs
Looks like they recommend running the return from the pump to the cell. Im just saying thats the way I ran it, and never had a problem with YEARS of operation. http://www.malloryperformance.com/pdf/5250_5250A.pdf
[Re: Big B]
#692569
05/08/10 11:57 PM
05/08/10 11:57 PM
Posts: 8,165 Left Coast
BobR
Left Coast
The pressures you have listed are adequate. Do nothing.
[Re: Big B]
#692570
05/09/10 05:45 AM
05/09/10 05:45 AM
Quicktree
Don't Holley carbs have needle and seat problems over 8psi? I notice that when I lower the psi to 7psi the engine idle much better. At 9psi I think I am pushing fuel past the seat causing the engine to idle richer. I have the Mallory fuel log and a -12 return line, so I definitely don't have a restrictoin in the return line. It seem to work fine. It's been doing this for 8 years.
I know quite a few people running 9 pounds and over. mine is set at a little over 9. -12 is good but do you have a bunch of 90s or bends? go to RobbMc's web site he may have the info to check the system.thats what you need to do and stop all the guess work. or PM him he was an engineer at mallory.
[Re: Big B]
#692572
05/09/10 08:43 PM
05/09/10 08:43 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Just to clear my confusion, when you say "with return style regulator" are you referring to the pumps internal regulator or a separate bypass regulator mounted near the carb?
I have the Mallory 250 pump, and it puts out a good 15-16 psi to my bypass regulator mounted on the intake manifold where the regulator reduces the pressure to the carb to 7psi.
Also, what is the inlet side of the pumps setup? What level in relation to the tank / fuel cell? Is the Inlet -8 AN or larger? Do you have a filter before the pump, and how restrictive is it if you do?
[Re: 451Mopar]
#692573
05/09/10 09:40 PM
05/09/10 09:40 PM
Big B
Greenville, WI
I have the Mallory 4302M fuel log with bypass regulator built in. Supposed to be good to 300gph. My fuel pump is located behind and below the tank with a -12 line going through a BG5000 fuel filter to the pump. A -10 to the regulator and a -12 back to the fuel cell. The fuel cell has foam in it. Not sure if that will cause a problem. It doesn't sound like it's that big a deal. In 2 years I'm switching to fuel injection anyways
[Re: Big B]
#692574
05/10/10 06:35 PM
05/10/10 06:35 PM
451Mopar
Aurora, Colorado
That is some huge lines. The Mallory 250 pump I have was only sized for -8 fittings?
