Re: Stock RB Valve cover question
[Re: Dougsmopars]
#692377
05/08/10 04:11 PM
05/08/10 04:11 PM
340dart4spd
Parts Problem
Parts Problem
The 70 and up are taller. There raised up in the center section. Change might have been 71 but i think they started in 70
so other then all the extra tabs..these would be correct height for a 70 car
[Re: cuda-sweden]
#692381
05/09/10 02:53 PM
05/09/10 02:53 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
also,those pictured covers have all the holes in the right places for a 70 valve cover.as in oil- fill hole,pcv,airbreather.but the raised middle section is wrong.
those are not c orrect for a 70. Too tall. 73 or later I would guess
[Re: dave571]
#692382
05/09/10 04:24 PM
05/09/10 04:24 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
they look allmost exactly to mines on 74 Charger... but not that tall.
passenger side has on mines some tabs for number 8 spark plug wire instead the intermediate looms ( 2º and 4º )
[Re: JohnRR]
#692386
05/10/10 06:25 PM
05/10/10 06:25 PM
340dart4spd
Parts Problem
Parts Problem
Those are 74and up covers, maybe late 73 and up , but definitely NOT 70 covers , open your wallet WIDE for a set of correct 70 covers .
again..thanks john..you are a wealth of knowledge
[Re: 340dart4spd ]
#692387
05/10/10 08:53 PM
05/10/10 08:53 PM
Posts: 1,183 eganville ont
440beep
eganville ont
the 71 cars build on aug 70 to jan 71 have same ones as 1970 cars build on aug 69 - july 70
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
[Re: Hemiruss]
#692390
05/10/10 10:28 PM
05/10/10 10:28 PM
Posts: 21,427 It's a dry heat
gtx6970
It's a dry heat
1970 ,,,,,,,,,, C-body
