727 kickdown and shift linkage ???
#691819
05/07/10 08:44 PM
05/07/10 08:44 PM
Posts: 130 Marcell, MN
68 Roadrunner
Marcell, MN
I finally got the motor and tranny back in my Roadrunner after 2 years! Now I can't remember how the column shift linkage or kickdown go back together. Does anyone have a diagram or good pics? Thanks!
1968 Roadrunner 383 auto
.060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
Re: 727 kickdown and shift linkage ???
[Re: Dads426]
#691822
05/07/10 09:12 PM
05/07/10 09:12 PM
68 Roadrunner
Marcell, MN
Thank you!!!! That is exactly what I needed! Back out to the garage!
[Re: 68 Roadrunner]
#691823
05/07/10 11:17 PM
05/07/10 11:17 PM
68 Roadrunner
Marcell, MN
Now does anyone know why my new / used TCI torque converter doesn't bolt up to my stock 383 flex plate. I knew it took the larger bolts so I drilled out the holes in the flex plate before I put it back on. But now I have the motor and tranny back in the car and I go to bolt up the converter and the holes don't line up!
[Re: 68 Roadrunner]
#691824
05/07/10 11:21 PM
05/07/10 11:21 PM
Posts: 93 CA
mojavered
CA
You probably already did this, but did you spin the flex plate all the way around? It only lines up one way.
71 Challenger RT 440 / 727 / 8.75
[Re: mojavered]
#691825
05/07/10 11:25 PM
05/07/10 11:25 PM
68 Roadrunner
Marcell, MN
Yeah I tried that, but it seems like the TCI has a smaller bolt pattern than the stock flex plate.
[Re: 68 Roadrunner]
#691827
05/08/10 03:36 PM
05/08/10 03:36 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The TCI converter likely has the 10" bolt circle and your flexplate has an 11" bolt circle. Factory flexplates come in either size.
[Re: John_Kunkel]
#691828
05/08/10 03:46 PM
05/08/10 03:46 PM
68 Roadrunner
Marcell, MN
Yeah you are exactly right. I ended up ordering an aftermarket one from KMJ Performance for 39.99.
