440HP Manifolds question
#69161
06/07/08 12:07 PM
06/07/08 12:07 PM
i have 906 heads on a 67' 440 block.
will the 68-69 HP manifolds fit? (yearone says their manifolds are 68-69)...
I saw on ebay that the 70' HP manifold has the drivers side at a different angle? is this true?
It's for a 70 B-body. 67' 440 block with 906 heads, what are my options?
Re: 440HP Manifolds question
[Re: THESHAKERPROJECT]
#69164
06/07/08 12:36 PM
06/07/08 12:36 PM
great thannks, i will have to get custom piping as I previously had long tube headers, so at least now I know 68-71 manifolds will work.
I've had it with the header heat problems burning wires, cooking starters, clanging around restricting clearance.....not worth it for me, I drive em on the street and don't do any racing.
[Re: rrunner]
#69166
06/07/08 01:04 PM
06/07/08 01:04 PM
rrunner, the pic looks like its cut off.
#69167
06/07/08 01:25 PM
06/07/08 01:25 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Yes they will fit but the flange on one side has a differant clocking than the 70/71 Hp Manifolds and they will not have the tabs for the heat tube if that matters. If you use TTI headpipes they will make them for the manifolds you use with your car.
yes , the pass side manifold is the one that has the different flange clocking , drivers side is the same clocking .
[Re: JohnRR]
#69168
06/07/08 04:22 PM
06/07/08 04:22 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Let's try again. Top shows 67, middle 68/9, bottom 70/1 If you need a 68/9 left side I have a extra.
[Re: rrunner]
#69169
06/07/08 07:32 PM
06/07/08 07:32 PM
rrunner, thanks i was going to ask you if you had a pair.
I'm going to keep my eyes out for a pair, year one also sells the new ones for 450 ish, comes with gaskets, bolts etc... I might go that route, not sure if its worth it.
