Re: Speedo Bench Test
[Re: BlakDak]
#691232
05/07/10 04:23 PM
05/07/10 04:23 PM
Posts: 3,892 Oregon
hooziewhatsit
I took one apart expecting to find a sticking cable. Turns out something in the speedo head was bad, and that was making it jump around. I mounted one of the square bits in a drill to test just the speedo. Once you get them out it should become apparent where the problem is.
[Re: hooziewhatsit]
#691233
05/07/10 06:42 PM
05/07/10 06:42 PM
Posts: 4,796 Castlegar, BC, Canada
That AMC Guy
I've cured many speedometer related issues simply by greasing the cable. I always like to use a high quality wheel bearing grease.
If the odometer is not working, then I would suspect further issues in the speedometer itself.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
