Speedo Bench Test #691230
05/07/10 04:12 PM
05/07/10 04:12 PM
Richmond, Va.
pittbulldog Offline OP
Richmond, Va.
Is there any way to bench test a speedo from a 71 Satellite? When I drive it bounces wildly, and the odometer doesn't work. I've got the car torn down now, and the console sitting on the bench. I've got another speedo from a 71 RR, but I have no idea if that one is good either. Thanks.
Re: Speedo Bench Test [Re: pittbulldog] #691231
05/07/10 04:16 PM
05/07/10 04:16 PM
a cornfield near you
BlakDak Offline
BlakDak  Offline
speedo cable and a drill.
Re: Speedo Bench Test [Re: BlakDak] #691232
05/07/10 04:23 PM
05/07/10 04:23 PM
hooziewhatsit Offline
I took one apart expecting to find a sticking cable. Turns out something in the speedo head was bad, and that was making it jump around. I mounted one of the square bits in a drill to test just the speedo.
Once you get them out it should become apparent where the problem is.
Re: Speedo Bench Test [Re: hooziewhatsit] #691233
05/07/10 06:42 PM
05/07/10 06:42 PM
Castlegar, BC, Canada
That AMC Guy Offline
I've cured many speedometer related issues simply by greasing the cable. I always like to use a high quality wheel bearing grease.
If the odometer is not working, then I would suspect further issues in the speedometer itself.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Speedo Bench Test [Re: That AMC Guy] #691234
05/07/10 07:30 PM
05/07/10 07:30 PM
Richmond, Va.
Richmond, Va.
Thanks. Hopefully between the two of them one will work.
