Re: Installing a trans
[Re: 6T6Cuda]
#691048
05/07/10 11:13 AM
05/07/10 11:13 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
It's always a good idea to slip the new disc over the trans input shaft beforehand, to be sure of fit. Too late for that, but you would not be the first to have alignment trouble, even after using tool to line up beforehand. I would try to use a prybar to depress fork to release the clutch, while wiggling the trans and inserting it further, while keeping it as parallel as possible to crank centerline. Also rotate tailshaft or trans itself, back and forth to help align teeth to clutch. If you're sure it gets into disc, then you have to be certain of proper engagement to pilot bearing too. Fun, ain't it?
[Re: DRJDVM]
#691052
05/07/10 10:31 PM
05/07/10 10:31 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
OK - I got it in A BIG thanks to the following people: challenger1 (Gary): Who dropped a 23 spline input shaft over to my house - clear on the other side of town! MarkZ (mark) for comming over and giving me enough crap to get it in; along with helping losen the pressure plate to realign the disk Mike: for helping me and turning the motor over so we can put the pressure plate back on... Thanks to all!
