Clutch linkage questions - 73 Challenger #690994
05/07/10 10:25 AM
05/07/10 10:25 AM
KS
MoparKansas Offline OP
KS
I am converting my 73 Challenger to a four speed and have a few questions on how the linkage goes.
1) Z-bar - does the larger "plate" protruding from the bar go near the inner finder or bellhousing?
2) Clutch pedal rod - does the longer end from the bend in the rod go towards the z bar or pedal?
3) Clutch pedal rod firewall boot - does the point go towards the engine compartment or interior?
4)Ball Studs - the reproduction units I bought one has a wider base that is not as thick and one has a narrow thicker base. Which goes on the bell and which goes on the frame bracket?
Thanks for all the help!
Re: Clutch linkage questions - 73 Challenger [Re: MoparKansas] #690995
05/08/10 12:51 PM
05/08/10 12:51 PM
KS
KS
BTT
Re: Clutch linkage questions - 73 Challenger [Re: MoparKansas] #690996
05/08/10 03:19 PM
05/08/10 03:19 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
I really dont know the correct way but as long as it lines up and give you the proper throw length it wont matter. make it work. sorry no ones give a better answer than that.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
