Broken Block - Passenger Side Trans Dowel Area #690743
05/06/10 09:38 PM
05/06/10 09:38 PM
Kansas
Menzaero Offline OP
Menzaero  Offline OP
Kansas
I did this tonight while installing the transmission; feel pretty stupid but life goes on. Can I have this welded or is it time to start searching for another block?
Re: Broken Block - Passenger Side Trans Dowel Area [Re: Menzaero] #690744
05/06/10 09:42 PM
05/06/10 09:42 PM
IMGTX Offline
IMGTX  Offline
What kind of engine is that?
Re: Broken Block - Passenger Side Trans Dowel Area [Re: Menzaero] #690745
05/06/10 09:45 PM
05/06/10 09:45 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Don't feel bad, I've broken a 318 the same way before...small blocks aren't overly robust in that area, it's the price of (relatively) light weight.
In my case I was removing the trans, and I took a chunk of the block with it...it may have already been broken there, don't know.
It can be welded w/o a problem.
Rich H.
Esse Quam Videri
Re: Broken Block - Passenger Side Trans Dowel Area [Re: IMGTX] #690746
05/06/10 09:45 PM
05/06/10 09:45 PM
Kansas
Menzaero Offline OP
Menzaero  Offline OP
Kansas
70 340 from my 70 Dart Swinger.
Re: Broken Block - Passenger Side Trans Dowel Area [Re: Menzaero] #690747
05/06/10 09:49 PM
05/06/10 09:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'm sure it can be welded somehow, and the indexing of that dowel is quite important. How'd you do that?
Re: Broken Block - Passenger Side Trans Dowel Area [Re: Menzaero] #690748
05/06/10 09:51 PM
05/06/10 09:51 PM
IMGTX Offline
IMGTX  Offline
For a 340 or orignal engine I would try to weld it. If it were a 318 or 360 I would look for a new block but that's me. If possible re-attach the side supports. Unfortunatly, it won't fit if you have headers.
Re: Broken Block - Passenger Side Trans Dowel Area [Re: buildanother] #690749
05/06/10 09:58 PM
05/06/10 09:58 PM
Kansas
Menzaero Offline OP
Menzaero  Offline OP
Kansas
I was tightening the bolts from the engine side of the transmission and snugging up the top transmission to engine bolts. I had about 3/8" gap all around and all of a sudden it snapped. Nobody's fault but my own; it is good to know that I can have it welded.
Re: Broken Block - Passenger Side Trans Dowel Area [Re: Menzaero] #690750
05/06/10 10:06 PM
05/06/10 10:06 PM
Kansas
Menzaero Offline OP
Menzaero  Offline OP
Kansas
The side supports will go back on as I am using the stock manifolds. I just had the engine
freshened up so I am kind of bummed right now. I bought the car from the original owner about 10 years ago, it's not the numbers block in the car as the original owner blew the engine in 1972 and put in another 70 date coded block.
