Want to see if my future camshaft will need the springs replaced on the heads. My Comp Cams Camshaft XE280HR-10 calls for :
Seat pressure is 115lbs
Open pressure is 388lbs
Rate is 395 lbs./in.
Will the stock Eddy RPM Valve Springs work?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
