Re: engine or trans prob????
[Re: WICKD6PK]
#690617
05/06/10 07:52 PM
05/06/10 07:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Get it hot and then turn it over with a torque wrench (get a base line first.... just warm)... if its a auto the trans shouldnt come into play
[Re: WICKD6PK]
#690622
05/06/10 10:17 PM
05/06/10 10:17 PM
MR_P_BODY
Mr p body not to sound stupid but what am i looking for when i do that? As far as the ground its grounded right to the starter bolts. Now on the timing (not to sound stupid here either) what difference would it make if the engine was hot or cold? There is no vac advance its a dist from 440 source basically a procomp dist. And as far as the starter wrap-blah didnt help at all Thanks again for the help guys
A substantial increase in torque.... but I dought its the problem.... more likely a timing issue
[Re: WICKD6PK]
#690625
05/06/10 10:46 PM
05/06/10 10:46 PM
MR_P_BODY
Ok i will try that now what diff does the timing make if its hot? now as far as locked timing i dont quite understand that im not sure of the init but total is 32 i believe
If the timing is too far it will fire the plug way before the piston is near the top and will cause it to crank hard or kick back.... does it have a advance type dist
[Re: WICKD6PK]
#690626
05/07/10 02:29 PM
05/07/10 02:29 PM
Posts: 25,904 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When the problem occurs disable the ignition and see if it turns over faster.
[Re: WICKD6PK]
#690628
05/07/10 05:32 PM
05/07/10 05:32 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
You need to look at all the basics first. How many amps is it drawing when cranking, how big of a ground wire and feed wire you have for the distance to the starter from the battery. how many amps will the battery load at. I have seen a inadequate ground wire (one not large enough) realy give alot of slow cranking hot problems. When the motor and the starter are hot they draw more amps so that is why more cable is needed.
JAKES AUTOMOTIVE
[Re: JAKE68]
#690629
05/07/10 08:26 PM
05/07/10 08:26 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
Do you use a master disconnect switch like is required if the battery is in the trunk?
If so, does all power run through the switch?
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
[Re: WICKD6PK]
#690633
05/08/10 02:52 PM
05/08/10 02:52 PM
Posts: 8,941 Holly/MI
Dean_Kuzluzski
Holly/MI
A small gauge wire will create more electrical resistance, hence a greater voltage drop. A thinner/smaller wire dissipates more heat. And then it's prone to melting its insulating layer and shorting, not a problem here but a good idea to keep in mind for an upgrade to overkill (0 Gauge). A longer wire will create a greater voltage drop per foot.
High compression, a lean carb setting and more mech. ignition advance together create more loading on the starter. When metal parts get warmed to running temp they swell and reduce clearances, ring gaps close up a bit and if all your machining is right that's what proper sealing will get you. All metals have an expansion rate relevant to heat.
Water in the combustion chamber can create a huge cranking problem, hydraulic lock, probably not in your case. I'd consider pulling the plugs and checking them while cranking it over to see how fast it'll spin.
It's probably an electrical issue with the battery leads being too long and too much voltage drop. Verify your connections as all clean and secure. Batteries full, no dry cells. How old are they? Do you run an alternator or have they been severely deep cycled to death too many times.
We've tried to help guys on this site troubleshooting racecar starter problems before and it's hard to analyze without being there. It's usually the simplest stuff that gets overlooked.
[Re: Dean_Kuzluzski]
#690634
05/08/10 03:01 PM
05/08/10 03:01 PM
JAKE68
Shelby mi.
You have 2 problems that I can see already. One The battery drop is too low. If you have around a 800 cca battery and it is load tested for the amperage it should not drop bellow 9.4 volts.Two you should not see that much drop at sol. So first look at your battery issue and then see how much a voltage drop you have at sol.
JAKES AUTOMOTIVE
