Extra header flange bolts/studs #690368
05/06/10 02:12 PM
05/06/10 02:12 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Looking to add extra fasteners to the middle flanges 440/906 heads. Who's done it, any tips?
Re: Extra header flange bolts/studs [Re: Mofopar] #690369
05/06/10 02:58 PM
05/06/10 02:58 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Extra header flange bolts/studs [Re: 340SHORTY] #690370
05/06/10 04:18 PM
05/06/10 04:18 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
You mean a second one as a lock nut?
Re: Extra header flange bolts/studs [Re: HitIt] #690371
05/06/10 11:54 PM
05/06/10 11:54 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Dang, I posted a pic but it didn't take.
Its a pic of the centre flange for 3 & 5 tubes, where an extra stud has been added on top and bottom to snug up the centre part of the flange. It was a from another thread here on Moparts. I can't access the pic form work, I'll try to post again in the AM.
Edit: The pic did upload - I just can't see it from work.
Re: Extra header flange bolts/studs [Re: Mofopar] #690372
05/07/10 11:52 PM
05/07/10 11:52 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Nobody's done this ?
Re: Extra header flange bolts/studs [Re: Mofopar] #690373
05/08/10 12:28 AM
05/08/10 12:28 AM
Nobody has . did that make it seal?
Re: Extra header flange bolts/studs [Re: RapidRobert] #690374
05/08/10 12:32 AM
05/08/10 12:32 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Thats a beefy flange, doubt you needed it. Interesting idea, I would be afraid of cracks off the exhaust ports.
Re: Extra header flange bolts/studs [Re: pishta] #690375
05/08/10 03:13 PM
05/08/10 03:13 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
That's not a pic of my stuff - just put it up as example.
Re: Extra header flange bolts/studs [Re: Mofopar] #690376
05/09/10 01:00 AM
05/09/10 01:00 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I think it's a great idea. Not only for the pressure it places in the middle of 2 ports that only have 2 bolts now but for stability too.
I admire the small block for it's 2 higher studs on the end and small Fords for their staggered bolt pattern. One up, one down etc. BB are all inline.
Where I see that as a minor potential problem is when the engine moves around on it's rubber mounts. The exhaust system is constantly yanking on the header assembly. This may eventually crush the top and bottom of the gasket, leading to a leak.
