Obnoxious leak out of my 727 #690327
05/06/10 01:52 PM
05/06/10 01:52 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
I've got a 727 behind my big block that will not stop leaking. Every time after I run or drive the car then park it it leaks from somewhere. I have replaced all of the pan bolts with studs and a new gasket. I have swapped speedo housings and O-rings several times. I have also changed the tailshaft seal. Am I missing something? I'm really racking my brain here and just thinking of letting the car sit and only drive my Roadrunner this year. It is beyond aggravating to have to put fluid in this car only to have it leak out.
Re: Obnoxious leak out of my 727 [Re: rck850] #690328
05/06/10 01:53 PM
05/06/10 01:53 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Common place is the shift shaft seal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Obnoxious leak out of my 727 [Re: HealthServices] #690329
05/06/10 02:02 PM
05/06/10 02:02 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Also replaciong the gaskey wont help if the pan rail holes are coined over. Easy to have happen in a stock type pan. Easy to hammer flat to.
Replacing the ouput shaft seal will only last a short time if the bushing is toast.
Re: Obnoxious leak out of my 727 [Re: WILD BILL] #690330
05/06/10 02:25 PM
05/06/10 02:25 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
the pan rail is fine when I put the studs in I looked that all over to make sure. Also the seal and bushing in the tailshaft are new and have been checked to make sure they were put in right and not worn. How hard is the shift shaft seal to replace? Thanks for the quick answers.
Re: Obnoxious leak out of my 727 [Re: rck850] #690331
05/06/10 02:26 PM
05/06/10 02:26 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
CLEAN the trans off well ... let it dry ...and the sprinkle-on some baby powder.
THAT will show where the leak is coming from.
Re: Obnoxious leak out of my 727 [Re: dOc …] #690332
05/06/10 02:42 PM
05/06/10 02:42 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
well I took off the trans cross member and where all the fluid is concentrated it seems like the small plate that hides the C clip the holds on the extension housing. I'm going to start there and clean the area and put either a new gasket/silicon or just silicon. Thanks
Re: Obnoxious leak out of my 727 [Re: rck850] #690333
05/06/10 06:42 PM
05/06/10 06:42 PM
BDW Offline
BDW  Offline
Re: Obnoxious leak out of my 727 [Re: BDW] #690334
05/06/10 09:31 PM
05/06/10 09:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Check this, took me awhile to find.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
BINGO!!!! that o-ring on the rear band shaft has sold a lot of pan gaskets for felpro etc. not too mention trans fluid.
The suggested fix may work, if not, it's a complete tear down to replace that O ring
Re: Obnoxious leak out of my 727 [Re: TJP] #690335
05/06/10 10:00 PM
05/06/10 10:00 PM
Kirkland, Washington
Pacnorthcuda Offline
I posted on that thread about the use of JB Weld. It did work fine--finally sold car. Wouldn't hesitate to do it again under the same circumstances.
Re: Obnoxious leak out of my 727 [Re: Pacnorthcuda] #690336
05/07/10 07:27 AM
05/07/10 07:27 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
My sons car was leaking from that oring,i jacked the back of the car up so all fluid went forward.I then cleaned and blow dried the area and covered it with red silicone,it was a rig but beat pulling the trans.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: Obnoxious leak out of my 727 [Re: moparmxz] #690337
05/07/10 10:04 AM
05/07/10 10:04 AM
scratchnfotraction Offline
jack up the back,clean with brake clean,air dry,cover with mopar black ATF/RTV and let cure over night
shaft seal is not hard and there are 2 of them,one for the throttle pressure valve lever under the e-clip and washer and the selector seal in the case
IMO it best to drop the valve body and use a jack screw to pull the seal into the case
and with the VB on the bench you can keep every thing from moveing when E-clip is removed,then use a pick to remove the rubber seal for the TPV,you can also clean up the part of the shaft that will be sliding thru the seal so it wont cut/roll the lip and leak
at this time when the pan is down ,I also replace the o-ring on the dip tube and use some of the mopar ATF?RTV on it as well
let cure over night and refill in the am
