Re: School me on 67 A body K frames
[Re: pauly v.100]
#690272
05/06/10 01:06 PM
05/06/10 01:06 PM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
Absolute go 73+ A body k-frame.!!!
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: Jim_Lusk]
#690278
05/06/10 10:03 PM
05/06/10 10:03 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Back to the original question, it really depends on how much use/abuse and what other changes/repairs are required. The big disadavantage of your '67 K is that one year only idler arm. I ran my '67 from '89 - 2002 with original /6 K, a 340, and a fair number of autocrosses. Over that span I replaced the idler 3 or 4 times and put on about 80,000 miles. So if you're only driving it 2-3000 miles a year it may not be worth the time and money to switch. OTH if you're already pulling the engine and suspension, or planning on some hard use, then it maybe it is worth swapping Ks. (So yes, I did finally switch to a '68 small block K)
The next disadvantage is the biscuit style mounts. My own experience has been that a simple solution to breaking the rubber bisquits was adding a solid torque strap. That was Schumacher's advice and recommendation when I called. Of course they also have the fail-safe biscuits and I think someone else is making another version that does the same thing.
Now if you're car already has a front sway bar and you want to switch to a '73+ K-frame, you will also need the matching through K sway bar and control arms with correctly placed tabs.
And not that you asked but a oouple of other uh, quirks of a '67 are the gas tank has only one strap (going side to side) and the one year only windshield weatherstrips.
[Re: Jim_Lusk]
#690281
05/07/10 07:47 AM
05/07/10 07:47 AM
Mattax
Phila. Pa.
You can run the early sway bar on the late k-member by drilling the mount holes and using early LCAs. Some of the 73 k-members have the front holes for the sway bar brackets.
Good point, and that's pretty easy to do.
