70 RR Door Weatherstrips?????? #689640
05/05/10 04:32 PM
05/05/10 04:32 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
There is a short piece of weather stripping that goes on doors, about 2" long. It goes at the end of the regular weather stripping on the end of the door. Does any one sell these? I know you don't get them when you buy the kits. Thanks for any info. Ronnie
Re: 70 RR Door Weatherstrips?????? [Re: okie] #689641
05/05/10 06:50 PM
05/05/10 06:50 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
the only folks i have used for weather stripping,is dante and aznick,both members here,yet i didn't replace those pieces,i was able to clean and scrub up with simple green and 0000steel wool,hope this helps
Re: 70 RR Door Weatherstrips?????? [Re: meepmeep70] #689642
05/05/10 06:53 PM
05/05/10 06:53 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
If I had some i would clean them up and use them. I had 2 sets of doors and didn't have one on any of them. I was looking at another car when I seen what I needed. If no one is making them they should Ronnie
Re: 70 RR Door Weatherstrips?????? [Re: okie] #689643
05/05/10 06:59 PM
05/05/10 06:59 PM
New Jersey
Dante Offline
Dante  Offline
New Jersey
Sounds like you are looking for the rubber strip that plugs onto the inner door at the end of the cat whiskers. They are available.
Dante's Mopar Parts
One of the countries largest Interior Dealer, e-mail for a discounted price quote.
Re: 70 RR Door Weatherstrips?????? [Re: Dante] #689644
05/05/10 07:02 PM
05/05/10 07:02 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
I don't know what they are called but I do need some. They are about 2" long and go right at the end of the weather strips. What do i ask for when I call? Thanks Ronnie
Re: 70 RR Door Weatherstrips?????? [Re: okie] #689645
05/05/10 08:16 PM
05/05/10 08:16 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
If your talking about the end of wiskers along the window edge then Dante has them. If your looking for the small ones that go at end of door weaterstrip, the one that goes around the door then i know soft seal has those. Dante might have them to.
Re: 70 RR Door Weatherstrips?????? [Re: okie] #689646
05/06/10 06:46 AM
05/06/10 06:46 AM
New Jersey
Dante Offline
Dante  Offline
New Jersey
You can call them weatherstrip end plugs and that would suffice
Dante's Mopar Parts
Re: 70 RR Door Weatherstrips?????? [Re: Dante] #689647
05/06/10 08:47 AM
05/06/10 08:47 AM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
They are called Window Weatherstripping Plugs.
Year One sells them.
This is what they look like installed.
Re: 70 RR Door Weatherstrips?????? [Re: okie] #689648
05/06/10 09:18 AM
05/06/10 09:18 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
ck your pm box
If you still need them let me know
