is 4.56's too much for me? #689303
05/05/10 08:57 AM
05/05/10 08:57 AM
South Carolina, United States
carolinacuda Offline OP
Hey fellas. I was thinking of using my 4.56 gears which have been sitting on shelf for several yrs now. My 74 cuda with a mild 440 has 3.91's in it now. I have a 3600 stall and run a hughes solid cam 252/256 @50 with 572.579 lift ,108lsa. Indy Ez's with Eddy victor Int. My 60 ft is around 1.60 and my eigth is 7.25 and 1/4 of 11.48 at 117. I shift at 6200 and cross line at about 6000. Im using a 28'tire. I figured those 4.56's were too much with that tire. Not sure what to do yet. I mostly drive on street (city drivin though)
Re: is 4.56's too much for me? [Re: carolinacuda] #689304
05/05/10 09:05 AM
05/05/10 09:05 AM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Ah yes, nothing like driving a performance vehicle on the highway at 50mph getting passed by a Toyota Prius!
This post is available in double vision where drunk.
Re: is 4.56's too much for me? [Re: carolinacuda] #689305
05/05/10 09:11 AM
05/05/10 09:11 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Too tall for the street and probably marginal for the strip.
Re: is 4.56's too much for me? [Re: carolinacuda] #689306
05/05/10 09:58 AM
05/05/10 09:58 AM
NJ
JCCuda Offline
JCCuda  Offline
NJ
Back in the early 80's I went from 3.91 to 4.56 gears in my 71 Cuda. It was a 440, 10.9 compression with mildly ported 915 heads a Crane hydraulic 528/552 and I think 246/252 @ .050. It had a Torker with a vac.780 and a 727 with a Select Performance 3500 stall 10" converter. If I remember correctly the car picked up about 2 tenths with the gear change. It was all steel with full interior(see pic.). I was shifting at it 6,400-6,500 and I think going through at about 6,800. Best ET/MPH at that time was 11.72/117. Tire was 11.5x28.5x15. It drove good around town but you couldn't really do much highway driving. If you don't do to much highway driving with it I think I would give them a shot. Shifting that thing higher and going through higher has to be worth a couple tenths with your combo.
Re: is 4.56's too much for me? [Re: carolinacuda] #689307
05/05/10 10:18 AM
05/05/10 10:18 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Crossing the line at 6k now with the 391's. it seems to me you are optimized now.
456 may even slow you down
Re: is 4.56's too much for me? [Re: dave571] #689308
05/05/10 12:00 PM
05/05/10 12:00 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
With Indy EZ heads a Victor intake and a cam that's 252/256 @.050 there is no way that thing is done at 6000 RPM. That combo optimally should be going through the traps at around 6,500-6,800 RPM.
Re: is 4.56's too much for me? [Re: carolinacuda] #689309
05/05/10 12:08 PM
05/05/10 12:08 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Most cars do not see there best ET with a shift point higher then cross rpm.
The only way to find out is try them and different shift/cross rpms.
Re: is 4.56's too much for me? [Re: carolinacuda] #689310
05/05/10 12:12 PM
05/05/10 12:12 PM
You got the third member, if you know (?)how to switch them make the change and let us know what you think afterwards
Re: is 4.56's too much for me? [Re: carolinacuda] #689311
05/05/10 12:23 PM
05/05/10 12:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Look at your gear change as a percentage and then
figure that percentage change in your rpm(I dont see
it being a problem) but if you spin the tires you arent
gaining anything... JMO
Re: is 4.56's too much for me? [Re: MR_P_BODY] #689312
05/05/10 02:43 PM
05/05/10 02:43 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
My uncles has a 68 RR with a mild 440,.509 hyd cam,10:1,mild heads,3800 converter,28x14.5 QTP's with 4.56.
It goes low 11's,shift around 6400-6500 and cross the same.
RUN'EM!!!!!!
Re: is 4.56's too much for me? [Re: MIKES_DUSTER] #689313
05/05/10 07:48 PM
05/05/10 07:48 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
I have 2 center sections for my Dart dragcar.One has 4.10's and the other has 4.86's in it.My car has a best of 11.48 in the 1/4 and 7.27 in the 1/8 with the 4.10's with the mild small block .With the 4.86's its crossing the line in the 1/8 at 6200 rpm and with the 4.10's its crossing at 4900 in the 1/8.It runs a better 60' with the 4.86's (1.57-1.58) ,but costs me a bit in the lights .With the 4.10's it will 60' around 1.60 or 1.61 .Believe it or not it runs exactly the same ET with either gear in it in the 1/8,but its easier to get it to leave and proly easier on parts with the 4.86's in the 1/8 anyway.I gain a bit off the line but give it back on the other end.BTW the 4.86's are useless for the 1/4 in my application thats why im hanging on the 4.10's for the 1/4 races .Confused yet ???..
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
383man [Re: carolinacuda] #689314
05/06/10 02:06 AM
05/06/10 02:06 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow my 63 would be a good race with your Cuda as my best is 11.49. I can tell you I use 906 heads I did some porting on. I run 4.30's with a 30" radial Hoosier slick. I drive on the street all the time like that. I shift about 6200 and hit the stripe about 6400 and I have the MP .557 solid cam. 4.56's with a 28" tire will be twisting your 440 pretty good for the combo. But you do have Indy EZ heads and a Victor intake (I use the Holley SD) so it may handle it. I am thinking if you shift about 6400 you should trap around 6600 maybe ??? Good luck , Ron
Re: 383man [Re: 383man] #689315
05/06/10 02:19 AM
05/06/10 02:19 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I'd say it might come down to a maximum of 1-1/2 - 2 tenths. Is it worth it considering your city driving... maybe not.
Would I put them in? Absolutely.
Re: is 4.56's too much for me? [Re: carolinacuda] #689316
05/06/10 06:58 AM
05/06/10 06:58 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well first I get a shift point for that engine of 7000 to 7200. try 6800 and work your way up!! those heads really like it up high. you not giving that intake and those heads a chance to show their stuff.
I ran 4.56 on the street with 4.56 gears fine if you don't cruise the highway too much 4000 rpm is 72 mph with 28 inch tall tires. Thes motors will cruise all day at 4000.
2 to 3 tenths for the 4.56 (likely 3 tenths quarter and .2 in the 1/8) shifting it a 7000 will likely net .2 to .3 more ?? but with a 28 inch tire look for high 10's but 7000 out the end.
Perfect for your motor would be 29.5 slicks with the 4.56 or 4.30 gear and 28 inch tall either would still give 11.00's at 6800 out the end
Re: is 4.56's too much for me? [Re: carolinacuda] #689317
05/06/10 07:07 AM
05/06/10 07:07 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Where did you degree that cam in 106. the first thing I would do if you sticking with that tight converter is advance it to 102 and move the shift points up to 6800 minimum and i'll bet you find you 10.999's just with that.
Re: is 4.56's too much for me? [Re: Dodgem] #689318
05/06/10 08:33 AM
05/06/10 08:33 AM
Thanks for your responses guys. Yea i've been debating on raising shift points. Just didnt want to push her too much. I think i will try these gears and and raise shift rpms and see what happens. I guess i can always go back to what i got.
