Re: is 4.56's too much for me?
[Re: carolinacuda]
#689305
05/05/10 09:11 AM
05/05/10 09:11 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Hey fellas. I was thinking of using my 4.56 gears which have been sitting on shelf for several yrs now. My 74 cuda with a mild 440 has 3.91's in it now. I have a 3600 stall and run a hughes solid cam 252/256 @50 with 572.579 lift ,108lsa. Indy Ez's with Eddy victor Int. My 60 ft is around 1.60 and my eigth is 7.25 and 1/4 of 11.48 at 117. I shift at 6200 and cross line at about 6000. Im using a 28'tire. I figured those 4.56's were too much with that tire. Not sure what to do yet. I mostly drive on street (city drivin though)
Too tall for the street and probably marginal for the strip.
[Re: carolinacuda]
#689309
05/05/10 12:08 PM
05/05/10 12:08 PM
Posts: 2,026 Trumbull,CT.
jim sciortino
Trumbull,CT.
Most cars do not see there best ET with a shift point higher then cross rpm.
The only way to find out is try them and different shift/cross rpms.
[Re: carolinacuda]
#689311
05/05/10 12:23 PM
05/05/10 12:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Look at your gear change as a percentage and then figure that percentage change in your rpm(I dont see it being a problem) but if you spin the tires you arent gaining anything... JMO
[Re: MR_P_BODY]
#689312
05/05/10 02:43 PM
05/05/10 02:43 PM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
My uncles has a 68 RR with a mild 440,.509 hyd cam,10:1,mild heads,3800 converter,28x14.5 QTP's with 4.56. It goes low 11's,shift around 6400-6500 and cross the same. RUN'EM!!!!!!
383man
[Re: carolinacuda]
#689314
05/06/10 02:06 AM
05/06/10 02:06 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Wow my 63 would be a good race with your Cuda as my best is 11.49. I can tell you I use 906 heads I did some porting on. I run 4.30's with a 30" radial Hoosier slick. I drive on the street all the time like that. I shift about 6200 and hit the stripe about 6400 and I have the MP .557 solid cam. 4.56's with a 28" tire will be twisting your 440 pretty good for the combo. But you do have Indy EZ heads and a Victor intake (I use the Holley SD) so it may handle it. I am thinking if you shift about 6400 you should trap around 6600 maybe ??? Good luck , Ron
Re: 383man
[Re: 383man]
#689315
05/06/10 02:19 AM
05/06/10 02:19 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
I'd say it might come down to a maximum of 1-1/2 - 2 tenths. Is it worth it considering your city driving... maybe not. Would I put them in? Absolutely.
[Re: carolinacuda]
#689316
05/06/10 06:58 AM
05/06/10 06:58 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Well first I get a shift point for that engine of 7000 to 7200. try 6800 and work your way up!! those heads really like it up high. you not giving that intake and those heads a chance to show their stuff. I ran 4.56 on the street with 4.56 gears fine if you don't cruise the highway too much 4000 rpm is 72 mph with 28 inch tall tires. Thes motors will cruise all day at 4000. 2 to 3 tenths for the 4.56 (likely 3 tenths quarter and .2 in the 1/8) shifting it a 7000 will likely net .2 to .3 more ?? but with a 28 inch tire look for high 10's but 7000 out the end. Perfect for your motor would be 29.5 slicks with the 4.56 or 4.30 gear and 28 inch tall either would still give 11.00's at 6800 out the end
