Roller rocker ? #688563
05/04/10 09:08 PM
05/04/10 09:08 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
I have gone through you know what looking for a set of roller rockers that will clear a 1.55 spring on my small block. I really don't want to keep buying them and then they don't work. I need suggestions please. Eddie headded smallblock with a roller cam. Thanks.
6.50 @105.26
Re: Roller rocker ? [Re: Kindafast] #688564
05/04/10 09:19 PM
05/04/10 09:19 PM
virginia
572stealth Offline
572stealth  Offline
virginia
Good evening Jose! sorry
Re: Roller rocker ? [Re: 572stealth] #688565
05/04/10 09:31 PM
05/04/10 09:31 PM
Seaford, Va
Seaford, Va
What are you doing inside ? Get back to work on your car.
6.50 @105.26
Re: Roller rocker ? [Re: Kindafast] #688566
05/04/10 09:34 PM
05/04/10 09:34 PM
virginia
572stealth Offline
572stealth  Offline
virginia
Just got done, must go to work in the AM. GTX is going to be running before the taxi.
Re: Roller rocker ? [Re: Kindafast] #688567
05/04/10 09:34 PM
05/04/10 09:34 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I wouldn't use anything but harland sharps on your combo.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: Roller rocker ? [Re: bdaz smblk] #688568
05/04/10 09:38 PM
05/04/10 09:38 PM
Seaford, Va
Seaford, Va
I spoke with Harland Sharp and nobody could answer if they would clear the springs. They said they should. That is a heck of a lot of money for a maybe. Do they clear on yours without grinding on them ?
6.50 @105.26
Re: Roller rocker ? [Re: 572stealth] #688569
05/04/10 09:41 PM
05/04/10 09:41 PM
Seaford, Va
Seaford, Va
Yea just in slow motion.
6.50 @105.26
Re: Roller rocker ? [Re: Kindafast] #688570
05/04/10 10:14 PM
05/04/10 10:14 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
We have them on a friend of ours car with the b1ba heads and they work great.Try Nick at compuflow he has good prices on them and a super person to deal with.
Re: Roller rocker ? [Re: bdaz smblk] #688571
05/05/10 01:36 PM
05/05/10 01:36 PM
Seaford, Va
Seaford, Va
Thanks, Just spoke with Nick today, He is going to get back with me. You are right "nice guy"
6.50 @105.26
