Big 2 bbl vs sm 4 bbl #688482
05/04/10 07:01 PM
05/04/10 07:01 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
I have a 65 Valiant rebuilt stock 273 2bbl motor It has a 4speed dual exhaust 81/4 sure grip with 373s I was thinking of adding a 4bbl but I also have a brand new 500cfm Holley 2 bbl,was wondering what the difference would be between a small 4 bbl 600 cfm or the 500 cfm 2 bbl
Re: Big 2 bbl vs sm 4 bbl [Re: gts1] #688483
05/04/10 07:55 PM
05/04/10 07:55 PM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
Finding a 4bbl manifold that has ports matching the 273 intake port will be a challenge. A 4bbl will provide better lowend torque, throttle response and better mileage. You would also have a port matching issue with the 500 cfm carb with the stock manifold. You would have to mill the ports for the butterflys to open.
600 double pumper is the way togo
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: Big 2 bbl vs sm 4 bbl [Re: Noblewk] #688484
05/04/10 09:13 PM
05/04/10 09:13 PM
Under My Car
Mopar_Country Offline
Under My Car
I would not go with a double pumper. With a stock engine I would say a 650 with vacuum secondaries.
Re: Big 2 bbl vs sm 4 bbl [Re: Mopar_Country] #688485
05/04/10 09:20 PM
05/04/10 09:20 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Cam is a big factor here.
In reality, it is the biggest factor in power, throttle response etc..
BUT that said, a small 4 bbl will be easier to tune,a nd easier on fuel. Probalby no difference in all out performance.
IMHO 600 is still too large for a stock 273 2 bbl motor. Holley makes 4bbl's into the 300's. 500 or so is plenty for that.
Re: Big 2 bbl vs sm 4 bbl [Re: dave571] #688486
05/04/10 09:28 PM
05/04/10 09:28 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
a stock 273 4bbl intake is pretty decent for a stockish 273 and the 500 eddy is probably going to work the best for a stockish 273.
Just an FYI the holley 2bbl will fit on a 360 2bbl manifold and the manifold can fit the 273 heads with a little grindinng of the bolt holes and port mis match is not too bad as the 2bbl manifolds have slightly smaller ports than a 4bbl manifold, but if it was me I would find a factory 273 4bbl manifold and run a small 4bbl.
Re: Big 2 bbl vs sm 4 bbl [Re: dave571] #688487
05/04/10 09:29 PM
05/04/10 09:29 PM
Kirkland, Washington
Pacnorthcuda Offline
I agree with the others that would go small 4 barrel vs big 2 barrel. Form my understanding the big 2 barrels were developed for racing classes that REQUIRE a 2V. and are almost always operated at or near WOT. Part throttle reponse sucks compared to a 4V with their much smaller primarys.
Re: Big 2 bbl vs sm 4 bbl [Re: Pacnorthcuda] #688488
05/04/10 10:26 PM
05/04/10 10:26 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The 4bbl progressively dumps in the air and fuel compared to the 2bbl that pretty much dumps n the full 500 at one time. Also remember the 500 cfm 2bbl will not flow as much air as a 500 cfm 4bbl because the 2bbl is rated at twice the vaccume leval the 4bbl is. The 500cfm 2bbl is about the same size as 1/2 of a 750 4bbl.
The 2bbl will be a little too much at low speeds and low throttle angles but not flow enough at WOT at higher RPM. Either c be made to work decent but I would still take the small 4bbl.
Re: Big 2 bbl vs sm 4 bbl [Re: gts1] #688489
05/04/10 11:04 PM
05/04/10 11:04 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
A 600 4 barrel would be my first choice but the 500 2 barrel will work fine, throttle response should be fine on a 273.
I used to run a 500 holley on a 120cid 4 cyl and never had a throttle response problem, it would light them up whenever I wanted, do donuts and get rubber in 4 gears
