engine numbers on '68 coronet 318 #68830
06/06/08 09:12 PM
06/06/08 09:12 PM
ne ohio
garymendy Offline OP
ne ohio
does anyone know where i would look to see if my '68 coronet 318 has a numbers matching engine and the trans too for that matter? i looked on the right side underneath and didn't see anything.
thanks a bunch!
garymendy@yahoo.com
Re: engine numbers on '68 coronet 318 [Re: garymendy] #68831
06/06/08 09:54 PM
06/06/08 09:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I don't think all 68s had the seriel on the block, only later ones. Should be found if it has it 90 degrees to the pan sealing surface on a flat pad if it had one. Also look for the casting date in big bold numbers on the side of the block.
Re: engine numbers on '68 coronet 318 [Re: HotRodDave] #68832
06/06/08 10:38 PM
06/06/08 10:38 PM
ne ohio
ne ohio
here is the build date of the car:
312 - SPD - Tuesday, March 12, 1968
would it have had numbers match?
