Re: removing power brake booster
[Re: scratchnfotraction]
#687977
05/04/10 10:36 AM
05/04/10 10:36 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
OK Thanks I have the 4 piston bendex system work good with new pistons and SS sleeves but very heavy so going wilwood race brakes (MP number) Where do I get this rod?? how do I put bolts in fire wall to hold master to it with booster removed? master power brakes http://www.mpbrakes.com/I do have the drum brake spindles of a 69 RR so I'm good there.
[Re: Dodgem]
#687979
05/04/10 01:11 PM
05/04/10 01:11 PM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
you cant buy the rod all by its self you got to buy a kit im in same boat needing just the rod and adpter plate already have new master cyl.
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
