removing power brake booster #687974
05/04/10 09:47 AM
05/04/10 09:47 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
What is involved to remove the power brake booster on a 1968 GTX to convert it to manual brakes???
Re: removing power brake booster [Re: Dodgem] #687975
05/04/10 10:01 AM
05/04/10 10:01 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
if you have drum brakes the master cylinders are the same. the firewall plates are different and you'll need a push rod.
Re: removing power brake booster [Re: lewtot184] #687976
05/04/10 10:25 AM
05/04/10 10:25 AM
scratchnfotraction Offline
you can make the plate with a template from the foam rubber gasket that the vac booster has
an adjustable brake rod from master power brakes is about 30$ and very good piece
Re: removing power brake booster [Re: scratchnfotraction] #687977
05/04/10 10:36 AM
05/04/10 10:36 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
OK Thanks I have the 4 piston bendex system work good with new pistons and SS sleeves but very heavy so going wilwood race brakes (MP number)
Where do I get this rod??
how do I put bolts in fire wall to hold master to it with booster removed?
master power brakes
http://www.mpbrakes.com/
I do have the drum brake spindles of a 69 RR so I'm good there.
Re: removing power brake booster [Re: Dodgem] #687978
05/04/10 10:43 AM
05/04/10 10:43 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
I was told my master would still work.
See master has a kit with rod, mount and master ??
http://www.mpbrakes.com/products/product-detail.cfm?product_id=137
Re: removing power brake booster [Re: Dodgem] #687979
05/04/10 01:11 PM
05/04/10 01:11 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
you cant buy the rod all by its self you got to buy a kit
im in same boat needing just the rod and adpter plate already have new master cyl.
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: removing power brake booster [Re: toplescuda] #687980
05/04/10 01:37 PM
05/04/10 01:37 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Well that adapter plate says no good for power to manual just 4 bolt to 2 bolt???.
Re: removing power brake booster [Re: Dodgem] #687981
05/04/10 03:33 PM
05/04/10 03:33 PM
I made a plate from 1/8 steel drilled 4 holes to mount to the fire wall and drilled 2 holes for MC
all holes need to be drilled in the fire wall
when I removed the vac booster there was a foam gasket with all the hole but the 2 for the MC that I drilled
I bought just the adjustable rod from master power brake for mine so it should be avalable by its self
you are looking at the wrong adaptor,that is to replace a 4 bolt mc with a 2 bolt one
sorta the asame thing but not
do you need a couple pics of mine?
I can send it to your email
Re: removing power brake booster [Re: scratchnfotraction] #687982
05/04/10 03:37 PM
05/04/10 03:37 PM
in the master link that is the right rod but wrong adaptor plate
you dont need and adaptor plate..you need a plate to renforce the firewall so it wont rip thur the thin wall when stomping on the brakes
I even bumped my 4 bolts up to 1/2 and used 2 allen head bolts and lock nuts for the mc
should be able to use the 4 holes that the booster used and just drill the 2 for the mc
Re: removing power brake booster [Re: scratchnfotraction] #687983
05/04/10 06:37 PM
05/04/10 06:37 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Thanks does the power brake booster unbolt from under the dash??
Re: removing power brake booster [Re: scratchnfotraction] #687984
05/04/10 06:44 PM
05/04/10 06:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ok...
What you need is the Manual brake firewall plate for your body style and year - got one at Moparfest last year for $20 from the guys from Quebec. They had a bunch.
Your iron 4-bolt m/c will bolt up to this plate but if you switch to an aluminum m/c then you need the adapter.
You can jimmy your "power" plate to work. Cut a piece of metal to fill the big hole and weld it in place. Line your m/c's bottom holes up with the bottom holes in the plate and drill two holes to match the m/c's top holes. Measure and bore a hole big enough for the m/c's flange to fit through.
You should also try to find the rubber boot that seals the back of the m/c.
The brake rod is sold separately - try Mancini's for either the standard or adjustable. Or find one off any Mope and make your own adjustable.
Re: removing power brake booster [Re: Stanton] #687985
05/04/10 06:50 PM
05/04/10 06:50 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
you should come up and help me!! LOL!!!
OK that sounds like a plan when I get my motor assembled and tranny gone through I'll look into it.
Thanks everybody.
