How to fix threads on a Master Cylinder #687932
05/04/10 09:02 AM
05/04/10 09:02 AM
Michgian
moparfun340 Offline OP
Michgian
How do I fix the threads on My Alum. Brake Master Cylinder. Do I try to find a bottom tap. Are the thread pipe threads. Thanks
for your help.
Re: How to fix threads on a Master Cylinder [Re: moparfun340] #687933
05/04/10 09:10 AM
05/04/10 09:10 AM
scratchnfotraction Offline
they dont cost much new
I got mine for 14$
its an inverted flare so I think you would have to remove all the guts to get a tap down the hole far enuff
not sure if the inverted flare threds are same as a pipe thred
IMHO,just get another one
I have a used one you can have if you want it also
Re: How to fix threads on a Master Cylinder [Re: scratchnfotraction] #687934
05/04/10 09:33 AM
05/04/10 09:33 AM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
Inverted flair is a straight thread not a tapered pipe thread.The new alumn.m/c aren't that much for the time and new seals...just my Just be careful,as it is your brakes we are talking about....
Re: How to fix threads on a Master Cylinder [Re: moparfun340] #687935
05/04/10 11:49 AM
05/04/10 11:49 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Sorry but as cheaply as replacements are this is one thing you don't [Edited by Moparts - Family Friendly Site - Keep it clean] with. You fix it by replacing it.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: How to fix threads on a Master Cylinder [Re: HealthServices] #687936
05/04/10 12:08 PM
05/04/10 12:08 PM
michigan woods
imfixinmopars426 Offline
michigan woods
if just the first part of the thread is messed up,you might try and take a steel male nut from a brake line,carefully file V grooves in each side,and slowly use it as a tap to straighten out the threads. if its a generic master,buy new...if its a original correct one,try and save it
