sealing rocker shaft studs
#687880
05/04/10 04:03 AM
05/04/10 04:03 AM
Posts: 3,210 robin hood country
deaks
robin hood country
What do you put on rocker shaft studs to keep them from trying to unscrew when taking the shafts on and off. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: sealing rocker shaft studs
[Re: Stanton]
#687885
05/04/10 01:33 PM
05/04/10 01:33 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
I believe the top thread is finer than the bottom so the coarser thread will have the tendency to loosen first. Since the bottom are only supposed to be put in finger tight the only solution would be loctite (blue).
This is the CORRECT answer
