sealing rocker shaft studs #687880
05/04/10 04:03 AM
05/04/10 04:03 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
What do you put on rocker shaft studs to keep them from trying to unscrew when taking the shafts on and off.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: sealing rocker shaft studs [Re: deaks] #687881
05/04/10 04:22 AM
05/04/10 04:22 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You could bunger up a thread to make an interference fit, but dont tell anyone I told you.
Re: sealing rocker shaft studs [Re: deaks] #687882
05/04/10 07:31 AM
05/04/10 07:31 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Proper torque !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: sealing rocker shaft studs [Re: deaks] #687883
05/04/10 08:59 AM
05/04/10 08:59 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I believe the top thread is finer than the bottom so the coarser thread will have the tendency to loosen first. Since the bottom are only supposed to be put in finger tight the only solution would be loctite (blue).
Re: sealing rocker shaft studs [Re: Stanton] #687884
05/04/10 09:13 AM
05/04/10 09:13 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I've put loctite thread locker on and it looks like it's worked.
Thanks Mick
Re: sealing rocker shaft studs [Re: Stanton] #687885
05/04/10 01:33 PM
05/04/10 01:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This is the CORRECT answer
