Converting 4wd 727 to 2wd
#687873
05/04/10 01:33 AM
05/04/10 01:33 AM
Posts: 4 Sacramento, CA, USA
steeters
Sacramento, CA, USA
I am going to buy an AMC bell pattern TC727 from a 4wd Jeep. My interest is using it as a back up for an AMC Javelin.
I understand that the tailshaft is different, and I've been told that the output shaft is different as well.
I know a little bit about my way around a TF/TC transmission, but what's involved in swapping out the output shaft? I assume that replacing the tailshaft only involves unbolting the old, and bolting in the new.
Specialized tools required? full transmission rebuild required?
Thanks,
Steve
AMC Fan
'70 Javelin SST 390 (now 401 with TC727)
Re: Converting 4wd 727 to 2wd
[Re: scratchnfotraction]
#687876
05/04/10 01:11 PM
05/04/10 01:11 PM
steeters
Sacramento, CA, USA
Thanks for the information guys. I passed on the purchase after seeing it.
I think I could have handled the swap, but I didn't realize the Jeep guys notched and hacked away at the case to suit their application. Had a hole for the CPS sensor, had a hole for a relocated vent tube, etc.
I'll stick to the 2wd stuff for now on.
Steve
AMC Fan
