Re: Need some advice on a SFI pressure plate
[Re: Cab_Burge]
#687786
05/04/10 02:15 AM
05/04/10 02:15 AM
Posts: 1,260 Netherlands
72Challenger
Netherlands
If memory serves correct I say Cab is spot on. Although the flywheels can be get in multiple weights. I believe my last McLeod steel flywheel 143teeth was 30lbs which ran fine in my streetcar. Had it combined with a CF dual friction setup which didn't hold up the power / weight.
Now that the same engine is put into my race backed up with a GForce stick I went with a custom setup. Build by Advanced Clutches with a total weight of the flywheel AND clutch assembly of around 18lbs. Runs and sounds completely different now. Just don't know how that holds up to streetuse...
As said maybe one of the gurus will chime in. I'm nowhere near a guru destroying all kind of parts every time...
