What is the alignment of your attach bracket and the bottom adjuster... Your pulleys may not be causing an misalignment, but if the whole unit is not in it's proper position in space, it'll never line up. Also, which water pump and crank pulley are you using? Have you any pictures with all three installed on the motor?
A '67 motor/configuration would have the regular big block non-a/c water pump pulley you see on 383 and 440 4bbl's until, say '71. This is the reason the alternators with one-groove pulleys work.. The '66-'68 2-groove crank pulley is different than the '69 and later.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi)
