Hydraulic Clutch Question #687622
05/03/10 08:48 PM
05/03/10 08:48 PM
Wisconsin
MagnumExpress Offline OP
Wisconsin
I am looking to install hydraulic clutch set up in a 66 Barracuda. Does any one use one or know where to locate parts for this. I would like to use a hyraulic release bearing if available for the 833 trans. any help would be appreciated.
#9 in the world. 2006 IHRA Super Rod
2010 IHRA Div.5 Hot Rod Champion
Re: Hydraulic Clutch Question [Re: MagnumExpress] #687623
05/03/10 10:22 PM
05/03/10 10:22 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I'm using generic wilwood parts, wilwood master cyl and slave cyl to actuate the stock clutch rod. The hydraulic throwout bearings are very expensive and problematic from what I've heard.
Re: Hydraulic Clutch Question [Re: DaytonaTurbo] #687624
05/03/10 11:10 PM
05/03/10 11:10 PM
IN
ahy Offline
ahy  Offline
IN
I'm using a hydraulic clutch with hydraulic TO bearing on a Keisler 5 speed setup. It has worked well and been reliable. Keisler could supply the master cylinder, pushrod and resovoir. Not sure if the TO bearing would fit a 4 speed. Check their web site or call. It would also be worth a call to one of the 4 speed specialists like Brewer.
Re: Hydraulic Clutch Question [Re: ahy] #687625
05/04/10 09:27 AM
05/04/10 09:27 AM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
i am using the wilwood stuff on my T56 that i adapted to work behind a mopar smallblock. seems to work ok. i use a hydraulic throw out bearing also. had a hard time bleeding it out to work good though.
Re: Hydraulic Clutch Question [Re: MagnumExpress] #687626
05/04/10 11:20 AM
05/04/10 11:20 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
I used this with good results on my drag car.
Would be fine on street.
fits 18 spline.
on shelf now.
