1969 440 HP Heat Riser Rebuild Kit #687610
05/03/10 08:44 PM
05/03/10 08:44 PM
Kentucky USA
RR6BBL1969 Offline OP
Kentucky USA
Anybody got a source on a heat riser rebuild kit for a 1969 440 HP ? Mine is good except for the shaft bushings and the heat riser spring is broken. Parts source , or a complete kit will do. Thanks!
Re: 1969 440 HP Heat Riser Rebuild Kit [Re: RR6BBL1969] #687611
05/04/10 02:07 AM
05/04/10 02:07 AM
Fitchbug, Mass.
WannaRunner Offline
WannaRunner  Offline
Fitchbug, Mass.
Rebuild/new kits are available, I am pretty sure I seen them from one of the Moparts sponsors,I can't remember which though, sorry, check e-bay. A heads-up, a kit (new) with all the hardware is $300-$400
Re: 1969 440 HP Heat Riser Rebuild Kit [Re: RR6BBL1969] #687612
05/04/10 01:35 PM
05/04/10 01:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
None of the 67-69 exh manifolds I have seen had shaft bushings , didn't see those till 70 model year.
I have an NOS repair kit , don't remember if it has bushings in it .
Re: 1969 440 HP Heat Riser Rebuild Kit [Re: JohnRR] #687613
05/04/10 03:35 PM
05/04/10 03:35 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Repair kits have bushings so that you can drill out the original hole, use the new kit and have a good seal.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 1969 440 HP Heat Riser Rebuild Kit [Re: MOPARMIKE69] #687614
05/04/10 07:03 PM
05/04/10 07:03 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
All kit's came with bushings.
Re: 1969 440 HP Heat Riser Rebuild Kit [Re: RR6BBL1969] #687615
05/04/10 08:33 PM
05/04/10 08:33 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
Who sells them??
Re: 1969 440 HP Heat Riser Rebuild Kit [Re: Hemiruss] #687616
05/04/10 08:38 PM
05/04/10 08:38 PM
Kentucky USA
Kentucky USA
Would the parts houses have them? Or maybe a dealership would have a kit. Anybody got a part number? Thanks
Re: 1969 440 HP Heat Riser Rebuild Kit [Re: RR6BBL1969] #687617
05/04/10 10:00 PM
05/04/10 10:00 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
All i need is the thermal spring. Those sold seperate? if so where?
Re: 1969 440 HP Heat Riser Rebuild Kit- Vendors? [Re: Dougsmopars] #687618
05/05/10 08:47 PM
05/05/10 08:47 PM
Kentucky USA
Kentucky USA
Anybody know of a source on the heat riser kit?
Re: 1969 440 HP Heat Riser Rebuild Kit- Vendors? [Re: RR6BBL1969] #687619
05/05/10 09:03 PM
05/05/10 09:03 PM
Dougsmopars Offline
Dougsmopars  Offline
Year one has them. At least they used to. I think they were around $350.00.
Re: 1969 440 HP Heat Riser Rebuild Kit [Re: 62maxwgn] #687620
05/06/10 11:44 AM
05/06/10 11:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Nice collection of parts, as usual, Bill
Re: 1969 440 HP Heat Riser Rebuild Kit [Re: Hemiruss] #687621
05/06/10 12:20 PM
05/06/10 12:20 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Who sells them??
Brad's NOS sells them 179.00
