Another six pack ?? #687513
05/03/10 05:57 PM
05/03/10 05:57 PM
ar
bobs68 Offline OP
bobs68  Offline OP
ar
The six pack works fine. When i warm it up good and turn it off for a few minutes and try to start it back it's flooded. The floats are set fine,i changed the powervalve because someone told me they can leak. Once again i am stumped.
Re: Another six pack ?? [Re: bobs68] #687514
05/03/10 07:11 PM
05/03/10 07:11 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
and the choke is not closing on u? when u go to the restart?
Re: Another six pack ?? [Re: bobs68] #687515
05/03/10 07:16 PM
05/03/10 07:16 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I bet you it's one of the end carb float levels.
I know personally I cannot set them level with the bottom of the hole. Will flood every time.
Set them a hair below so that the fuel doesn't dribble out at all.
I thought I had mine set properly too.
Re: Another six pack ?? [Re: superwrench] #687516
05/03/10 08:37 PM
05/03/10 08:37 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
after shuting off look down the carb barrels of each carb to see if any fuel driping fuel if so on the outer carbs the metering plate scews loose
an on the center carb meter plate gasket bad
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
