Some MSD Coil Questions #687463
05/03/10 05:31 PM
05/03/10 05:31 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Has anyone used the blaster ss #8207?
any thoughts against a blaster 2?
Re: Some MSD Coil Questions [Re: Scamp408] #687464
05/03/10 07:37 PM
05/03/10 07:37 PM
AndyF Offline
AndyF  Offline
Yes, the 8207 works really well with the MSD e-curve distributor. I designed a bracket to hold the 8207 onto a Mopar intake manifold because nothing else was available on the market.
Re: Some MSD Coil Questions [Re: AndyF] #687465
05/03/10 08:58 PM
05/03/10 08:58 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
According to the chart it should work with the 6al box.I like it because its small and I can stick it anywhere.I know some of the other coils put out more spark but tehy are too big to hide.
Re: Some MSD Coil Questions [Re: Scamp408] #687466
05/03/10 10:43 PM
05/03/10 10:43 PM
AndyF Offline
AndyF  Offline
Here is another picture of a bracket for the MSD 8207 coil.
Re: Some MSD Coil Questions [Re: AndyF] #687467
05/04/10 05:00 AM
05/04/10 05:00 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I was going to put it on the fire wall in place of the wiper motor. Thanks guys for all the help.
Re: Some MSD Coil Questions [Re: AndyF] #687468
03/11/12 03:31 AM
03/11/12 03:31 AM
AndyF Offline
AndyF  Offline
I also came up with a bracket for the big-block engines. This bracket works best with single plane intakes that have room between the runners.
Re: Some MSD Coil Questions [Re: AndyF] #687469
03/11/12 10:00 PM
03/11/12 10:00 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
As of the 2011 SEMA show the 8207 solid state coil had compatibility problems with E-curve distributors. Early versions did not apparently have this problem.
I bought a E-curve and 8207 in early 2011 and exchanged the E-curve for another a few months later. The E-curves would not run with the 8207 coil.
At last SEMA I explained my dilemma to the MSD booth and they said to run a oil filled coil. I put on an oil filled coil and it worked great. No issues. Nice unit.
I have no idea if MSD has resolved this compatibility issue since last Nov.
Re: Some MSD Coil Questions [Re: autoxcuda] #687470
03/11/12 10:37 PM
03/11/12 10:37 PM
They need to resolve the issue of their cheap a$$ blaster II terminals breaking off with very little torque put on them!
I barely tightened mine down and it broke, leaking oil out all over the place.
When I really examined it, it was a lot cheaper than the one I had purchased ~10 years ago.
