4.7L V8 ~80k miles.what preventive maintenance needed? #68737
06/06/08 05:34 PM
06/06/08 05:34 PM
NC
DCM71cuda Offline OP
NC
2003 Durango that wife drives.
Have had really no problem at all with the engine. I have done oil changes, trans fluid, filters, etc.... very regularly. Are there any issues that repeatedly come up on these engines when they get miles on them?
Thanks.
Re: 4.7L V8 ~80k miles.what preventive maintenance needed? [Re: DCM71cuda] #68738
06/06/08 11:07 PM
06/06/08 11:07 PM
NC
NC
Re: 4.7L V8 ~80k miles.what preventive maintenance needed? [Re: DCM71cuda] #68739
06/06/08 11:53 PM
06/06/08 11:53 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
spark plugs every 30K PCV every 60K , a FIS will clean carbon off pistons and valves .
Re: 4.7L V8 ~80k miles.what preventive maintenance needed? [Re: DCM71cuda] #68740
06/07/08 12:54 AM
06/07/08 12:54 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Have 2 of them with over 120k miles each and no problems or funky noises yet.
Re: 4.7L V8 ~80k miles.what preventive maintenance need [Re: DCM71cuda] #68741
06/07/08 10:33 AM
06/07/08 10:33 AM
PA
noplanb Offline
noplanb  Offline
PA
04 Dakota with 71K, no issues at all. Mobil 1 and PureOne filter every 5K.
The 4.7 got an early rep as a sludger, but if you get the oil up to temp regularly and use a good synthetic, no problem.
Weird thing with mine, when new I used GTX 5W-30 dino, it used a quart every 2000 miles. I switched to M1 5W-30, used a quart every 5000, and still does 4 years later. I guess I have a hot spot above the flashpoint of GTX but below M1. Go figure. Just a fun little reminder of the German occupation.
remember when you said honey, some day that car is gonna look so good in front of our house
