What year did Mallory produce MP distributors? #687280
05/03/10 12:04 PM
05/03/10 12:04 PM
808CUDA Offline OP
808CUDA  Offline OP
Just installed an MP P3690428 (dated 12/20/05) and wondering is this one of them Mallory built distributors.
If so, are they any good or need a lot of work out of the box. I just don't seem to get the same snappy throttle I did with my 'ole cast iron dual point.
I read in the tech archives RobbMc's report on the Mallory distributors and suggested reducing the mechanical advance so initial timing can be increased, if so, anyone know exactly how to do this procedure?
Thanks in advance!
Re: What year did Mallory produce MP distributors? [Re: 808CUDA] #687281
05/03/10 12:47 PM
05/03/10 12:47 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
Don't have a year, but they have a brass shaft under the rotor, if it is brass it is on of the good ones.
You need a spring / advance kit (about 15 or so) from mallory to adjust it.
They are good dist once you get them dialed in...
Re: What year did Mallory produce MP distributors? [Re: 6T6Cuda] #687282
05/03/10 03:07 PM
05/03/10 03:07 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Pictures of both on my website's distributors page
Good question wrt the year.
Also I've posted some info on the springs earlier today in the thread titled 'recurving a MP electronic ignition'.
In general the MP distributors need to be reworked because Sheppard apparently insisted on lots of advance instead of more initial and less advance. My .02 is to find a shop with a distributor machine. That will be the quickest way set the mag pickup dizzy to match the advance curve of your dual point. Even if you need to do the tinkering yourself it will be a time saver.
Re: What year did Mallory produce MP distributors? [Re: Mattax] #687283
05/05/10 06:48 PM
05/05/10 06:48 PM
5thAve Offline
5thAve  Offline
I bought mine around 2000 or 2001 and it's the new kind.
