Re: Six Pack Problems
[Re: Warrant_Officer]
#687246
05/03/10 11:19 AM
05/03/10 11:19 AM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
Yes a back-fire can take out the power valve. Is the engine "stock" or modified? For modified motors, it is recommended you replace the metering plate in the outboard carbs to one that accept standard Holley jets so you can tune the end carbs for proper fuel mixture at WOT rather then richening the primaries.
You might want to check with ProMax Carbs (Moparts Sponsor) for your fuel bowl and or other parts for the six pak. They specialize in Mopar 6-paks, from rebuilds, complete stock restorations, to full race applications.
Scott
#687249
05/03/10 12:08 PM
05/03/10 12:08 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
are the outboard linkages supposed to be loose or tight.it seems that if they are tight the idle will change.. thanks again
your idle should stay the same w/ the outboards hooked up or if they are not. If the idle picks up then you need to adjust it out.
