mopar siamese block ID ? #687229
05/03/10 10:14 AM
05/03/10 10:14 AM
Calgary Alberta
Darkside Racing Offline OP
Calgary Alberta
right side has large mopar emblem
1.5 " high " mopar " letters
a small shield emblem with m and c ? in it
4 bolt mains (with funny litle studs and nuts on ties)
any info on where it came from please?
david@darkside.ca
PM or post
Thanks.............
David Fedorowich DarkSide Racing parts@darkside.ca www.darkside.ca Calgary Alberta T3G 4B1 403-547-6691
Re: mopar siamese block ID ? [Re: Darkside Racing] #687230
05/03/10 10:36 AM
05/03/10 10:36 AM
MI
Blown69 Offline
mopar addict
Blown69  Offline
mopar addict
MI
Do you have the casting number off the side of the block?
Re: mopar siamese block ID ? [Re: Blown69] #687231
05/03/10 10:46 AM
05/03/10 10:46 AM
Calgary Alberta
Calgary Alberta
246833-M
I asumed it was a mopar performance
but understood they came from different places ??
Re: mopar siamese block ID ? [Re: Darkside Racing] #687232
05/03/10 04:23 PM
05/03/10 04:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you have the block in your possession ?
Re: mopar siamese block ID ? [Re: JohnRR] #687233
05/03/10 08:34 PM
05/03/10 08:34 PM
Calgary Alberta
Calgary Alberta
yup putting it in the wifes dart
Re: mopar siamese block ID ? [Re: Darkside Racing] #687234
05/04/10 12:15 PM
05/04/10 12:15 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
SS Hemi block. This was the old ones that didn't have the lifter bores machined. Pre-World block.
Floyd Lippencott IV
Re: mopar siamese block ID ? [Re: mr_340] #687235
05/04/10 12:20 PM
05/04/10 12:20 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Other side.
Floyd Lippencott IV
Re: mopar siamese block ID ? [Re: Darkside Racing] #687236
05/04/10 01:29 PM
05/04/10 01:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Since heads are on I don't think you can check it easily ...
edit ... just looked , there is a service replacement 440 block with crossbolted mains , it's part number P5007672 , the siamese is P5007624 and P5007625
Re: mopar siamese block ID ? [Re: Darkside Racing] #687237
05/04/10 02:00 PM
05/04/10 02:00 PM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
my block has a part number stamped into a little boss in the same spot as the oil filter on the RIGHT side of the engine.. You have to look at the front of the engine to see it... Front lower left while looking at the timing chain area.. Thats where my numbers are... mopar siamese wedge...
Re: mopar siamese block ID ? [Re: Darkside Racing] #687238
05/04/10 03:11 PM
05/04/10 03:11 PM
Calgary Alberta
Calgary Alberta
here is some more pictures
the shield shaped emblem has a M and a C in it
- tie bolts on bottom
no numbers around oil filter corner
Thanks for the help
Re: mopar siamese block ID ? [Re: Darkside Racing] #687239
05/04/10 03:14 PM
05/04/10 03:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks for the help
You just answered your question with that picture , looks like there is no freeze plug in it , if it's not there that looks like a siamese bore block to me , there is no gap between those 2 cylinders .
Re: mopar siamese block ID ? [Re: Darkside Racing] #687240
05/04/10 03:15 PM
05/04/10 03:15 PM
Calgary Alberta
Calgary Alberta
It was never used when I picked it up (new)
but could be 10-15 years old ?
picture without heads
Re: mopar siamese block ID ? [Re: Darkside Racing] #687241
05/04/10 03:19 PM
05/04/10 03:19 PM
Calgary Alberta
Calgary Alberta
yes definatly a siamese block but was wanting to know who made it for mopar I assumed it was world when I got it but apparently it is older than that.?
Re: mopar siamese block ID ? [Re: Darkside Racing] #687242
05/04/10 04:28 PM
05/04/10 04:28 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Well, it's a Megablock.
Beyond that, there isn't much to ID it because not much was required in the way of serialization. It just wasn't important way back then, I guess. Here's your block, have fun.
Mopar's normal past practice was, take a casting and machine it as many different ways as possible (to get as many different part numbers as possible from one tool).....however once the box is gone there's no telling what part number it was originally sold as, so there's where the "have fun" part comes in. Ex: your casting number could have either been a Wedge or a Hemi depending on how it was machined.
Unfortunately things are never quite as simple as "who made it" because of the multi tiered supply chain. MC is the foundry mark. Far as I'm aware MC did not do machine work or packaging, they just sent raw castings along to whatever the next step of the supply chain was at the time.
The modern blocks have many more identifying marks, and are serialized in such a way that normal human beings can read it and make sense out of it without a secret squirrel decoder ring. And if that isn't enough, the packaged part number is even engraved on the newer blocks, so no need to save boxes for 15 years anymore to remember what part number you have Progress!
Re: mopar siamese block ID ? [Re: ZIPPY] #687243
05/04/10 10:41 PM
05/04/10 10:41 PM
Calgary Alberta
Calgary Alberta
thanks ...
I appreciate the info
so in summary the mega block is any moparperformance block after the heavy web (direct connection) hemis we used to get for our old fuelers .... to the new world ones ?
and have got to be a little better than digging around the local auto wrecker .... probably weighs more though ?
