Which MIG welding helmet should I buy?
#687054
05/03/10 06:27 AM
05/03/10 06:27 AM
Posts: 179 Auburn, Indiana
The Duster
Auburn, Indiana
I want an auto darkening one, and I am leaning towards the Hobart XVS or would like to stay in that price range or less ($145). I will be buying from Sears website as I have gift cards. Many thanks, Roy
Re: Which MIG welding helmet should I buy?
[Re: The Duster]
#687055
05/03/10 07:32 AM
05/03/10 07:32 AM
Posts: 1,443 Maryland
Dads426
Maryland
-Adjustable Auto-Darkening feature, -Largest Viewing Area; so you aren't looking through a "tunnel," -Solar Powered (light from arc powers it with/without a small backup battery.) If the Hobart one has those features, then buy it.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: TheHemi]
#687057
05/03/10 07:24 PM
05/03/10 07:24 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I am very happy with my Miller Stars and Strip helmet it may be marketed under Hobart now.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#687060
05/04/10 09:04 AM
05/04/10 09:04 AM
Posts: 3,482 Cold Spring, NY
1970GTX
Cold Spring, NY
Me too
[Re: cudabitten]
#687061
05/04/10 09:37 AM
05/04/10 09:37 AM
Posts: 473 MI
Blown69
mopar addict
mopar addict
MI
I bought one of these last year (50 dollar harbour freight), works great so far. Also bought leather welding gloves there as well. Both still work fine.
[Re: Blown69]
#687063
05/04/10 11:10 AM
05/04/10 11:10 AM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I've had a couple. One was from HF and one was sold by Lincoln. Both solar only. They both worked fairly well but I suggest keeping them dry, charged and/or out of extreme temps. I left one in the sun to charge too long and I think it burned it out. The other one, I got caught in a sudden but brief summer down pour and its dead too. Also, I had them in an unheated garage and in the dark for long periods over the long Nebraska winters. When it got warm enough to "play" again, they took a long time to charge, which is why I left the one out too long. For now I just use one of the large filter lenses sandwiched between two cover lenses clipped between a spring clip that doubles as a handle. Improvise, adapt, and overcome
[Re: The Duster]
#687067
05/04/10 06:58 PM
05/04/10 06:58 PM
Scott Carl
Omaha, Nebraska
I'm now thinking of getting a Speedglas 9002X for around $240 or so because of the very large field of view Viewing Area: 4.09" x 2.13" (104mm x 54mm) . What do you guys think?
again, thanks for all of the help.
Roy
Comfort is an important key to good welding skills and the better you can see, the more comfortable you will be
