Roller cam and bronze drive gear #686961
05/02/10 11:49 PM
05/02/10 11:49 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I have read time and again about how roller camshafts require a bronze gear for the oil pump drive. Can anyone help me to understand why? Did the factory cams require this? I don't remember anything different in the 3 or 4 roller small blocks that I have pulled apart.
The reason for the softer oil pump drive gear had to do with dissimilar metals, and that its easier to change a worn oil pump drive than the cam. Why didn't the aftermarket make them out of the same metal as with flat tappet cams? If the bronze gear wears, what about the debris? Can we trust the oil filter to screen all of it from the oil?
I ask this because I have considered switching to a roller cam to insure that I won't have to swap camshafts again unless I want to. Cam failures are a real pisser.
Re: Roller cam and bronze drive gear [Re: Kern Dog] #686962
05/03/10 12:02 AM
05/03/10 12:02 AM
AndyF Offline
AndyF  Offline
It all depends on the material used to make the camshaft. You can buy hyd roller cams for SB motors that use the factory oil pump gear. As far as I know all of the Mopar solid roller cams require a bronze gear but it is possible that someone has a cast core roller cam or a two piece setup.
Re: Roller cam and bronze drive gear [Re: AndyF] #686963
05/03/10 02:40 AM
05/03/10 02:40 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Does it make a difference in camshaft material whether the cam is for use with solid lifters or hydraulic? ALSO, what about the shavings from wear on the soft oil pump drive gear?
Re: Roller cam and bronze drive gear [Re: Kern Dog] #686964
05/03/10 06:48 AM
05/03/10 06:48 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
Most roller cams are made from billet steel which isn't compatible with a standard oil pump/dist drive. Mine doesn't have a fuel pump lobe either which I wasn't too thrilled about. I understand there's some wear of the bronze gear mostly during break in.
Re: Roller cam and bronze drive gear [Re: Kern Dog] #686965
05/03/10 01:39 PM
05/03/10 01:39 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
The billet steel of the roller cam and the steel drive gear will cold weld (transfer material) so they must be dissimilar metals. most cams are cast
Re: Roller cam and bronze drive gear [Re: Dodgem] #686966
05/03/10 07:45 PM
05/03/10 07:45 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
I run a Crane "Retro-fit Roller" cam in my 360 and they took the billet steel cam and pressed on a cast oil pump drive gear to the shaft so I can use a standard oil pump drive shaft/gear setup. Works great! I believe they make some for big blocks as well.
Re: Roller cam and bronze drive gear [Re: Alikazam] #686967
05/04/10 01:55 AM
05/04/10 01:55 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Didn't CRANE go out of business? If so, I guess I'll have to check elsewhere. Thanks guys1
Re: Roller cam and bronze drive gear [Re: Silverbullet2] #686968
05/04/10 06:07 AM
05/04/10 06:07 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Does a Comp Cams 280 Roller Hydraulic have a fuel pump lobe? Mine is buried in my garage. If it does...I am pooched
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Roller cam and bronze drive gear [Re: Kern Dog] #686969
05/04/10 12:23 PM
05/04/10 12:23 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
http://www.aftermarketnews.com/Item/61767/crane_cams_back_in_business_under_new_ownership.aspx
They are back in business under new ownership, so maybe give them a call and see if these cams are being produced. They still show them on the website at least and some New Old Stock is probably around somewhere as well.
