has anyone put a 66-70 k member into a 62-65 b body? #686860
05/02/10 08:53 PM
05/02/10 08:53 PM
greeneville, tn
the nitro man Offline OP
greeneville, tn
has anyone put a 66-70 k frame into a 62-65 b body? what all is gained by doing this? how hard is it, & does anyone have any pictures?
thanks
Re: has anyone put a 66-70 k member into a 62-65 b body? [Re: the nitro man] #686861
05/02/10 09:28 PM
05/02/10 09:28 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
it sets the engine/trans backwards.. makes it a pain to hook up to the trans x member..
I am truckless..
Re: has anyone put a 66-70 k member into a 62-65 b body? [Re: 340SHORTY] #686862
05/02/10 09:53 PM
05/02/10 09:53 PM
Maxie intake manifold won't fit without surgery.
Transmission mount will have to change as well and the bellhousing bolts will be a paint to access.
Unless you're looking for every last hundreth in the quarter, it's really not worth it. If you already have a 66-70 K-frame and are replacing a /6 it might be a good option.
Re: has anyone put a 66-70 k member into a 62-65 b body? [Re: the nitro man] #686863
05/02/10 11:08 PM
05/02/10 11:08 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Moving the firewall for Max Wedge intake clearance is actually pretty easy. Porta power against the K-Frame will push it back nicely. I cut the front trans mount boss off from the trans cross member,fab a small box section and use a Chevy S-10 mount. It also allows the use of 66 & up headers. Trans tunnel clearance is tight. I opened mine up.
Doug
Re: has anyone put a 66-70 k member into a 62-65 b body? [Re: dvw] #686864
05/03/10 11:35 AM
05/03/10 11:35 AM
greeneville, tn
greeneville, tn
i'm putting in a low deck 500ci engine, procomp aluminum heads & a tunnel ram. i don't think i'll bother with it. sounds like more trouble than it's worth. the header thing would be a plus, but thats about it.
