Re: Anyone know flow cfm on avs
[Re: roddo63]
#686807
05/02/10 08:03 PM
05/02/10 08:03 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I was wandering what a 1968 factory 440 4spd AVS carb flowed for cfm. Thanks
IIRC...625 CFM
[Re: GO_Fish]
#686809
05/02/10 11:46 PM
05/02/10 11:46 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
In 68 they were not real concerned with emmisions, a PCV valve was the only significant thing, mabey an extra vent line here or there. The AVS was just a step forward with the AFB carb desighn. They flowed around 600 cfm depending on whos bench you beleive.
[Re: roddo63]
#686810
05/03/10 12:07 AM
05/03/10 12:07 AM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
440 375HP had a carter rated at 750cfm , the 350HP engine had the 625 .
[Re: nz383man]
#686812
05/03/10 04:29 AM
05/03/10 04:29 AM
RapidRobert
I'm thinking the 625/750 are listed cfm's and someone had posted that they dont actually flow near that high but I am not positive is that info is correct
[Re: roddo63]
#686813
05/03/10 06:29 PM
05/03/10 06:29 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The literature handed out at the old Performance Clinics had pretty low numbers compared to what everybody thinks they are, 383/440HP were 585/635.
