Battery voltage at coil positive #686728
05/02/10 06:25 PM
05/02/10 06:25 PM
Eastern Ontario
shaker340 Offline OP
Eastern Ontario
I am only getting 3v at the coil positive with the wire on and 8v with the wire off, any suggestions what is causing this?
Thanks, Mike
2008 Challenger SRT8
1940 Chrysler Royal coupe
Re: Battery voltage at coil positive [Re: shaker340] #686729
05/02/10 10:08 PM
05/02/10 10:08 PM
Sharpsburg, GA
rusthole Offline
rusthole  Offline
Sharpsburg, GA
Do you have a points distributor? Rotate the engine and measure again.Closed points will cause that.
Re: Battery voltage at coil positive [Re: rusthole] #686730
05/03/10 02:15 AM
05/03/10 02:15 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Well 3 volts isnt enough, im not sure what youre saying by "on" and "off" but you wont have 12V at the coil unless the engine is cranking. The ballast resistor reduces the voltage to the coil when the engine is running to around 9V.
Re: Battery voltage at coil positive [Re: GTX MATT] #686731
05/03/10 05:06 PM
05/03/10 05:06 PM
Eastern Ontario
Eastern Ontario
I have electronic ignition in the car. I get 3 volts when the wire is attached to the coil and 8 v when the wire is not attached to the coil with the key in run position.
Re: Battery voltage at coil positive [Re: shaker340] #686732
05/03/10 05:36 PM
05/03/10 05:36 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
When the wire is disconnected, you are seeing the Potential voltage. The supplied voltage to the component. With the key on, it's going through the resistor. With the key in Start, it will be battery voltage.
With the wire connected, it is powering the component and will drop.
Re: Battery voltage at coil positive [Re: RodStRace] #686733
05/03/10 07:04 PM
05/03/10 07:04 PM
Eastern Ontario
Eastern Ontario
Should I be seeing more than eight volts with the wire disconnected and key in run position ? From what I have read, I should be seeing 8v with the wire connectedin run position . I have not tried cranking the starter over to see what the voltage is when the wire is attached....what should it be? within 1v of battery voltage?
