Starting rebuilt 440 - Running HOT?!?!
#686621
05/02/10 04:22 PM
05/02/10 04:22 PM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
I just cranked the 440 and ran it for about 10 mins. Is it normal for a newly rebuilt engine to run really HOT? I didn't set my timing yet with the light but I have the initial at 8 deg BTD. Thanks! Steve
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
Re: Starting rebuilt 440 - Running HOT?!?!
[Re: Plum440]
#686623
05/02/10 04:34 PM
05/02/10 04:34 PM
RapidRobert
toss the stat/put a large shop fan in front of it/check timing as your up @~2500 rpm. Assuming carb/mixture isn't way lean (might toss in some larger jets for the breakin/wont hurt things). Glad ya shut it down when you saw a prob. How hot was it?
[Re: RapidRobert]
#686624
05/02/10 04:43 PM
05/02/10 04:43 PM
Plum440
Slidell, LA
It was about 250...really HOT!
I've got a mild cam in her and throught the carb was running a little rich (new Eddy 750). It was spitting flames the first couple of trys.
[Re: Kern Dog]
#686626
05/02/10 05:57 PM
05/02/10 05:57 PM
Plum440
Slidell, LA
Thanks for the tip! I'll do that next time I crank it. What else do I need to look for? I filled the radiator up after I cranked it that first go round. IT took quite a bit more fluid. Good thing that I don't see any water spewin' on the garage floor or in the oil pan!
[Re: Plum440]
#686630
05/02/10 08:25 PM
05/02/10 08:25 PM
Posts: 936 own private Idaho
ngpSatellite
own private Idaho
make sure your lower rad hose has a coil in it preventing the hose from colasping...also block your heat crossover on your intake manifold... just for starters...
[Re: Bill MeLater]
#686632
05/03/10 08:49 AM
05/03/10 08:49 AM
Plum440
Slidell, LA
Thanks guys! I'll try it again this week.
Is there a way to tell if the thermostat has closed becasue of the high temp other than removing it?
