Has anyone hooked up an MSD-6l with a factory tach
#686398
05/02/10 10:44 AM
05/02/10 10:44 AM
Posts: 1,175 Woodbridge
Tommy The Chryco
Woodbridge
I can't seem to get it working, I ordered there extra unit to install for factory tach but it still not working???? running a ralley cluster by the way. Hope someone out there has an answer....
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: Has anyone hooked up an MSD-6l with a factory tach
[Re: Tommy The Chryco]
#686399
05/02/10 07:30 PM
05/02/10 07:30 PM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
From The AutoInstruments.com website
"The Mopar factory tachs will not work with modern electronic ignition systems. We can modify your tach and replace the meter and board with modern components for $275. The tach will then work with any modern electronic ignition system."
I tried replacing a few things in mine way back when. It worked and blew out after 20 minutes. I left it alone and eventually replaced it with a quartz clock
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: ahy]
#686401
05/03/10 06:51 AM
05/03/10 06:51 AM
Tommy The Chryco
Woodbridge
did you use any additional wiring besides connecting the red and white wires respectively? or did you add an extra wire for the ignition coil?
[Re: ahy]
#686402
05/03/10 07:13 AM
05/03/10 07:13 AM
Posts: 657 Berlin NJ
scottk
Berlin NJ
I used a MSD-6 box with the adaptor for the tach. I hooked it up per the directions and it worked fine.
Me too....Used the msd tach adapter.
[Re: scottk]
#686403
05/03/10 01:05 PM
05/03/10 01:05 PM
Pyper70
Athens, Greece
I still have the msd tach adapter on my charger. I never removed it after the tach burned out. Maybe it was just bad timing on the side of the tic-toc-tac lifeterm
