Re: BDS intake manifold
[Re: royt440]
#686131
05/02/10 07:53 AM
05/02/10 07:53 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
i use silicone as fred said and the burst plate goes to the rear.the gap on my intake to the rail is about .100.i used some gasket glue to seal the intake gasket to the head/intake to be safe. did you tap for a boost guage in the intake?i did mine on the front 1/8npt.
[Re: royt440]
#686133
05/05/10 05:24 PM
05/05/10 05:24 PM
blownzoom440
ELYRIA,OH
i dont believe the bolt pattern on the intake for the blower will allow you to go backwards with it.my intake fiber gasket it .060 and only needed trimming on the devider between the ports.
Post deleted by Defbob
[Re: blownzoom440]
#686134
05/06/10 08:44 AM
05/06/10 08:44 AM
#686135
05/06/10 02:12 PM
05/06/10 02:12 PM
Posts: 42 Marshall, Texas
royt440
Marshall, Texas
I do remember the gasket only fit one way so I'll make sure the blower faces the right way ![](/ubbthreads/images/graemlins/eeek.gif) I'll try the manifold without the thick gasket. Thanks to all Roy
