CRANK POSITION SENSOR HOW TO TEST ? #68609
06/06/08 09:59 AM
06/06/08 09:59 AM
Slidell, La.
doctor_mopar Offline OP
Slidell, La.
I replaced the A518 trans in my 93 Ramcharger 318 2WD. Afterwards the engine would turnover, but not run. I checked and found no spark. I figured I may have damaged the crank position sensor. I changed it and still no spark. According to the shop manual you test accross terminals B and C with an ohm meter, and should get an open circuit. If you get a low ohm reading, the sensor is bad. Both the new and old sensors when tested, show open when the ohm meter leads are hooked up one way, but when you reverse the leads, it shows 660 ohms on the old sensor, and about 450 on the new one. I don't know if the sensors are good or bad, as the shop manual doesn't mention a difference in readings according to polarity. If the sensors are good, I am not sure what the problem is. I checked all connections, and I have the original flexplate on the engine. Anyone know how to test the sensor? Any suggestions on what may have gone out of whack. I t was running fine a week before I changed the trans. Thanks !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: doctor_mopar] #68610
06/07/08 07:58 AM
06/07/08 07:58 AM
Slidell, La.
Slidell, La.
Come on guys ! Any Magnum knowledge here ?
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: doctor_mopar] #68611
06/07/08 03:08 PM
06/07/08 03:08 PM
Slidell, La.
Slidell, La.
There is alot more knowledge available about the GM and Ford products ! You know what I will buy next .........
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: doctor_mopar] #68612
06/07/08 04:49 PM
06/07/08 04:49 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Doctor Mopar,thats a great screen name! Yep maybe it's time for a chebby. LOL
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: doctor_mopar] #68613
06/07/08 05:17 PM
06/07/08 05:17 PM
Andrewh Offline
Andrewh  Offline
well I looked it up in all data, and it says nothing different then your manual.
I do have to ask, are you sure your meter is any good. There should be no difference in how that circuit works no matter which way you plug in the connectors.
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: Andrewh] #68614
06/07/08 06:22 PM
06/07/08 06:22 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Engine will still start with bad crank sensor,just won't run above 3000-3500.Check the cam sensor wires leaving the distr/cam sensor housing.They like to crack there.
Leave the gun.......take the Cannoli's....Mike
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: doctor_mopar] #68615
06/07/08 06:58 PM
06/07/08 06:58 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Did the flex plate get bent?
I know what a pain those dipstick tube brackets can be and the sensor is right there. Did you man handle it at all?
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: UCUDANT] #68616
06/07/08 08:23 PM
06/07/08 08:23 PM
Washington Twp., Southern NJ
Fastfrankie Offline
Fastfrankie  Offline
If you have a Snap On MT 2500 Scanner you can find out real easy if that Crank Sensor is bad! Just a thought...maybe the "new" crank sensor is bad. Aftermarket are made overseas and are cheap. Is it a factory Mopar one?
I had a Buick Riviera - Supercharged 1995 with 3800 motor. I went through a crank sensor every 2-3 years. Then replaced it with a factory GM one and never replaced one again!
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: UCUDANT] #68617
06/07/08 08:44 PM
06/07/08 08:44 PM
Slidell, La.
Slidell, La.
Well Thanks for some effort guys ! The flexplate is not bent. I used a trans jack. My meter is good,and I beleive it reads in one direction because of the type of sensor this is. I believe the manual is wrong. I have used many Chrysler shop manuals, and many of the GM manuals, and have found the Chrysler manuals to be weaker in there diagnosis information.I have been a fan of the Chrysler musclecars since I was a kid in the sixties. I have owned and restored many of the Chrysler musclecars. As for the Chrysler products since the seventies, I am not as much a fan. I look at things realisticly ! For my bread and butter daily drivers I have had more difficulty with my Chrysler products. The reason I mentioned the possibility of my next automobile being other than Chrysler is just as simple as the reliability, expense, and of course knowledge and information to repair, which I find to be weak. I am hoping to be proven wrong, but even in my local area the information from the people I know with shops, and info from mechanics with the dealerships is weak. I hope that I get some real insite from this site! I don't need to get the doctor chebby comments,Prove ne wrong by information, or prove me right by a lack of it !I am really trying to repair my Ramcharger ! I have done mechanic work for over 40 years ! Every once in a while, I have something that stumps me ! I have ver7y little time off from my regular job, and I was just in hope of some help. Checking the cam position sensor is my next step planned. Anyone with more insite, let me know ! Thanks, Ron
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: Fastfrankie] #68618
06/07/08 08:56 PM
06/07/08 08:56 PM
Slidell, La.
Slidell, La.
Fastfrankie, The sensor I bought is a Borgwarner and made in the USA. I was going to get an OEM one at the dealer, but the parts man sounded confused on the phone, and told me there were several ones listed for it and he needed a number off the old one after I pulled it. He said none of them were in stock, and he would have to order it. None of this works for my time frame to work, and I don't believe his competance, as I have had nothing but trubble with them in the past. The reason I started my post here was to make sure how to test the sensors off the vehicle, so I could determine if I got a bad part. I don't have a scanner, and my friends don't have the adapters for their scanners on my vehicle. I still have a couple things to do before I give up and tow it to a shop that can scan it and fix it. Thanks
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: doctor_mopar] #68619
06/07/08 10:39 PM
06/07/08 10:39 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'll assume battery voltage and connections are good,very important. Have you checked for fault codes? Simple and can often lead to the problem. I don't see how swapping the leads during your testing could show the results you got,I just went to the garage and picked up a good CPS and couldn't get anything but infinite resistance no matter which way the leads are connected. Yes even NEW DEALER CPS can be bad out of the box,it does happen and I have first hand knowledge of this. You may want to double check the distributor cap if the back of the engine was lowered during your swap,they have been dislodged enough to cause a no start or very rough running engine and some
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: goldmember] #68620
06/08/08 12:14 AM
06/08/08 12:14 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Your magnetic CPS has to have 50thou clearance at the flywheel trigger. Turn the key on and rotate the crank by the crank bolt. Pierce the wires and check for voltage/signal, 4 times per 1 rpm as I remember. Measure your OEM sensor mounting depth length to the new one.
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: doctor_mopar] #68621
06/08/08 03:06 AM
06/08/08 03:06 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Check the wires that lead into the distributor for the hall effect trigger. Mine went bad right where they go into the hall effect trigger itself. I moved the wires and the truck ran.
Something else to check at least.
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: mike s] #68622
06/08/08 08:24 AM
06/08/08 08:24 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Absolutely unbelievable....If you don`t know the system..DON`T give incorrect advice!!!!
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: goldmember] #68623
06/08/08 11:02 AM
06/08/08 11:02 AM
Slidell, La.
Slidell, La.
Very good advice guys ! Since my old and replacement sensor both have resistance when measured one direction, sounds like they may both be bad. I am going to test another new one at the parts store first up. I had not checked for codes, but right now the crank sensor is not installed. I had already disregarded that statement that the engine would run just below 3000 rpm without the sensor, as that is contrary to everything I had read. I am going to work on the truck this morning, and with the advice I have received I hope to find the problem. I will post the results ! Thanks, Ron
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: Blown71X] #68624
06/08/08 11:31 AM
06/08/08 11:31 AM
Fastfrankie Offline
Fastfrankie  Offline
I am glad someone else pointed that out...I read that last night and laughed to myself. If your crank sensor is bad, you won't have spark and it won't run period!
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: Fastfrankie] #68625
06/08/08 01:05 PM
06/08/08 01:05 PM
fargo,nd
fk5hemi Offline
fk5hemi  Offline
fargo,nd
i have worked on a 96 avenger that missed on acceleration or load and found it was a bad crank sensor. that was after replacing all the sparkplugs , wires, distributor cap and rotor.
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: doctor_mopar] #68626
06/08/08 08:29 PM
06/08/08 08:29 PM
Slidell, La.
Slidell, La.
IT'S Fixed !!!!! The problem was a shorted wire near the speed sensor on the tailshaft. This wire is in common with the crank position sensor along with other sensors. I was not looking in the right area at first. Also there were no codes set and no codes shown when scanned. Also the crank position sensor does show resistance when ohmeter is hooked up one direction, and no continuty the other way, contrary to the shop manual stating it should just read open. ( I tested my old sensor and 2 new ones, and used 2 different meters. Anyway........ Lessons learned !!! Thanks to everyone for advice ! Ron
Re: CRANK POSITION SENSOR HOW TO TEST ? [Re: doctor_mopar] #68627
06/10/08 07:18 AM
06/10/08 07:18 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Oh I know about shop manuals and resistance testing. If it ever points to a componant. I like to swap in a known good part before buying a new part....been bitten.
