stealth heads #686125
05/02/10 12:51 AM
05/02/10 12:51 AM
s.e. michigan
top8x7b Offline OP
top8x7b  Offline OP
s.e. michigan
any problems ,good bad ? putting on 383 in duster with turbo action 3800 convertor 4.10 gears 750 dpumper carb ,holley street dominator intake comp cams 550 intake 570 exhaust.
Re: stealth heads [Re: top8x7b] #686126
05/02/10 12:55 AM
05/02/10 12:55 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Change the springs,retainers and locks.
Nautilus Racing-
Re: stealth heads [Re: Chris2581] #686127
05/02/10 01:01 AM
05/02/10 01:01 AM
s.e. michigan
top8x7b Offline OP
top8x7b  Offline OP
s.e. michigan
i did switched to 10 degree locks and retainers
Re: stealth heads [Re: top8x7b] #686128
05/02/10 03:13 AM
05/02/10 03:13 AM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
Have the valve job checked. I ported a set for a local racer and the valves and seats needed a little bit of attention.
Re: stealth heads [Re: super451b] #686129
05/02/10 07:38 AM
05/02/10 07:38 AM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
You will need to clearance the pushrods.
I ran them "out of the box" for a season with no issues. 10.90s with a flat top 440 in a 2750# Cuda.
I have since replaced the springs with Comp 928s using the same retainers and keepers. No problems.
