Re: 2002 Durango Overheating.................Please Help
[Re: scottk]
#686113
05/02/10 01:07 AM
05/02/10 01:07 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Do you by chance have a rear heater? If so, it takes forever to get bubbles out of the system. It took mine about two months. I followed the FSM recommendations but it did not help. Finally, just moderated the driving until it finally coughed up all the bubbles over about 2 months. Keep an eye on the overflow and make sure it never gets too low again. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#686115
05/02/10 08:08 AM
05/02/10 08:08 AM
Posts: 657 Berlin NJ
scottk
Berlin NJ
All great ideas. Thanks. With regard to the rear heat, was you car overheating too? And under what conditions? It never occurred to me to turn on the rear heat to try to purge air.
[Re: scottk]
#686118
05/02/10 04:55 PM
05/02/10 04:55 PM
denfireguy
Colorado
Mine started overheating climbing a mountain pass with the A/C on. Turned off the A/C and limped it home. The temp went down into just above where it normally was. Added coolant, did the FSM rev to 3000, with heat on both heaters on. It continued to overheat with just the air on or on a warm day. It was not losing coolant but seemed to always need more in the overflow tank. After shotgunning it didn't work winter came and it finally straightened itself out and quit sucking in more coolant from the tank. It has not overheated for a year now. In the middle of all this, I took it to a garage and the guy thought it was a cracked head or bad gasket. He was going to do a test to see if there was combustion products in the radiator. Unfortunately, the standard testers are designed to work on a radiator cap on top of a radiator and that is not how a 4.7 is set up. It tested good but he was skeptical. I took it back as he was suggesting tearing the engine down. A local guy here said he got the air out of the system by attaching a garden hose to the heater inlet and letting the water flow to the ground from the outlet through the heater hoses. When the stream was free of bubbles, he clamped them both off. He then added concentrated antifreeze to the radiator, hooked the hoses up and called it good. Never had trouble afterward. Craig
[Re: scottk]
#686121
05/03/10 12:31 PM
05/03/10 12:31 PM
Posts: 1,377 Ohio
Todd
Ohio
How can it be so hard to get the air out of these things? And this can cause all of this overheating? This stinks. The car has developed a noticeable miss over the last few days though. The miss does make me wonder about head gaskets. If you do a Google search tons of horror stories about the head gaskets come up. Oh boy, what to do??????
Sounds like you got it hot too many times. I would have started with t-stat long ago.Cheapest and easiest
[Re: Todd]
#686123
05/17/10 09:04 PM
05/17/10 09:04 PM
scottk
Berlin NJ
Todd. I see from you profile that you are a Chrysler tech. Have you seen many come through your shop with gasket problems?
