Cams utilizing the large mopar lifter surface area?
#686024
05/01/10 10:57 PM
05/01/10 10:57 PM
Posts: 583 San Antonio, TX
CurYellowBird
San Antonio, TX
I've been probably putting too much thought into this for my cam swap.
I know that the XE cams and probably the summit cams are based on the chevy lifter. Does this cause any drawbacks on a 383/440's performance since it does not utilize the max surface area of the lifter as mopar performance and other mopar cam dealers have set theirs up for?
Project War Bird:
1971 Plymouth Roadrunner
383 4 speed with air conditioning
GY3 Curious yellow
All original
Re: Cams utilizing the large mopar lifter surface area?
[Re: CurYellowBird]
#686025
05/01/10 11:02 PM
05/01/10 11:02 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
Mopar performance cams are not set up to utalize the mopar lifter.
Engle, comp, and hughes all do but comp only sells them if you get a custom cam, both Engle and hughes have them on the shelf.
You will not "lose" anything because even the factory cams don't make use of the large lifters but it is like free HP if you do use the special lobes. I honestly don't know a reason not to use them, even mild combos can benifit from useing the mopar specific lobes.
[Re: DaytonaTurbo]
#686029
05/01/10 11:31 PM
05/01/10 11:31 PM
HotRodDave
Kalispell Mt.
MM is comps most aggressive lobe for the .904 lifter. Yes parts failure can go up without makeing sure your lifter bores are perfect (bushed most likely) and good lifters to handle the aditional spring preasures. The smalles MM comp lobes start out above what I would call mild, hughes has some good ones that are not as wild.
[Re: HotRodDave]
#686030
05/01/10 11:34 PM
05/01/10 11:34 PM
HotRodDave
Kalispell Mt.
With out makeing sure your lifter bores are perfect I would recoment use the ford specific lobes instead of the MM to be on the safe side, they are more aggressive than a chevy lobe but not as aggressive as a mopar lobe.
